Pocket GPS World :: View topic - TomTom One
TomTom One
andy8
PostPosted: Thu Jan 05, 2006 12:15 pm    Post subject: TomTom One Reply with quote
Would appreciate if anyone knows if i can load the speed cameras database to my TomTom One which is using software version 5.410. Thanks.
Tim Buxton
PostPosted: Thu Jan 05, 2006 1:11 pm    Post subject: Reply with quote
Yes you can. I did it for a friend the other day (well, night actually). The database is compatible with any TomTom version (so far). It is the custom warnings that only work with certain versions (not 5.410) at the moment.
Tim
Privateer
PostPosted: Thu Jan 05, 2006 1:45 pm    Post subject: Reply with quote
Hi andy8,
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
andy8
PostPosted: Thu Jan 05, 2006 6:56 pm    Post subject: Speed Camera Reply with quote
Thanks for your help guys, i've managed to load the info onto my TomTom One successfully.
just need to go past some cameras now. Smile
22.063 (19 Jun 24)
