Pocket GPS World :: View topic - TT2
TT2
oleole
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: TT2 Reply with quote
I got a problem during the install. Or i got to install, but when i try to start it it says "Cannot determine the location of data. Please re-install data and/or application"
Have tryed to reinstall several times, is the HP 2210 the problem or???
PeterB
oleole,
Is this the first installation ot TT2 or the second????
If your using maps installed with a previous PDA then it won't run.
In this case yo need to re-intall maps on a card via the TT2 installation on the 2210.
I had this problem and now it works fine!!
PeterB, Kent, U.K.
oleole
I lost count on how many times ive tryed re-instaling. i have the tt2.2 on the hp2210, and the map i just copyied from my laptop over to the cf card. When i push the exe file the error comes.
Oleole, you can't just copy maps, you have to install them. That's why it's not finding the data. You have to use the TomTom installer program through ActiveSync to install the maps.
You need to install TomTom Navigator, Pocket Speech and GPS driver to main memory. Then you'll have an option of adding maps. Go through the process of installing the maps. When it's completed, you then need to activate the software so you can use the maps.
DavidW
The installer allows you to copy the maps using a card reader - you don't have to use ActiveSync if you have appropriate hardware.
As Dave says, you must run the map installer on the PC.
