Pocket GPS World :: View topic - Hp Ipaq 1710 & Tom Tom 5 Memory problems
clownfish
PostPosted: Sat Nov 19, 2005 12:47 am    Post subject: Hp Ipaq 1710 & Tom Tom 5 Memory problems Reply with quote
Hi guys, new to this forum so I hope you can help me! Sad
I have done a complete reboot of my Ipaq & installed the new 5.0 sofware & Maps. I have been on the TomTom support site & followed the instructions to get the full postcode list by copying the zip file from the SD card to 'my documents on 'my device' the problem now is that there is not enough memory to run tom tom!!!! & have I have not installed any other software on the ipaq & it has all it's factory settings.
The main reason i upgraded to v5.0 was for the fullpostcode facility. I haven't even tried to install the speed cameras yet!!
How do I remedy this?
Thanks in advance
Regards
lbendlin
PostPosted: Sat Nov 19, 2005 12:49 am    Post subject: Reply with quote
Do NOT attempt to install anything into RAM on this machine - it's just too small.
The postcode file needs to go into a \zip folder on the storage card.
The program itself also should be installed to storage card.
Lutz
TomTom/TeleAtlas NAVTEQ
clownfish
PostPosted: Sat Nov 19, 2005 12:53 am    Post subject: Reply with quote
The full postcode zip file is aleady on th sd card but tomtom won't seem access it unless it's in the my documents folder??
lbendlin
PostPosted: Sat Nov 19, 2005 12:55 am    Post subject: Reply with quote
no, that's not correct. It needs to be in a folder called zip.
There is a catch.
- UK 7 digit PostCode will not work until there is a Tomtom folder on the storage card (even though it can be empty). The postcode file has to be in the ZIP folder on the storage card.
Lutz
PostPosted: Sat Nov 19, 2005 1:00 am    Post subject: Reply with quote
Try this link, scroll down to Darrens posting and do what he says, it does work Wink Mike
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=29562&postdays=0&postorder=asc&start=0
clownfish
PostPosted: Sat Nov 19, 2005 1:51 am    Post subject: Reply with quote
Result!!!!!! :D
Thanks mike I think thats sorted it.
One other thing that I didn't expect is that when planning a route from home to a full post code it still then asks for a house number???? Confused
I use this a lot for business & they tend to be in units or ind estates, hence no house numbers! That's why I washoping the full post code list would just direct me straight there!
8O
TuurG
PostPosted: Sat Nov 19, 2005 1:13 pm    Post subject: Reply with quote
just leave the house number empty or choose Anywhere
GO1005
MGC GT 1968
MGB Cabrio 1973
clownfish
PostPosted: Mon Nov 21, 2005 11:06 am    Post subject: Reply with quote
But that wont pinpoint the address! Confused
Oldboy
PostPosted: Mon Nov 21, 2005 7:36 pm    Post subject: Reply with quote
It will get you close enough to see the 'writing on the wall'. Wink
lupos0_1
PostPosted: Tue Nov 22, 2005 10:31 am    Post subject: Reply with quote
Surely the postcode will direct you to the postcode 8O
If you are required to have any more detail, then you need to specify a location within that postcode.
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
22.055 (29 May 24)
