me__2001 Occasional Visitor
Posted: Sun Oct 23, 2005 9:24 pm Post subject: H6340 not picking up tomtom navigator 5 |
i've just bought the tomtom navigator 5 and the software has installed but i cant pick up the reciever. i have tried to add the reciever by following this guide
http://www.aximsite.com/bluetooth/bt_guide2.htm#section5
but the ipaq just keeps searching, does anyone have any idea why it cant be found ?
also the reciever is detected by my PC but i cant find the Ipaq using it ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Posted: Sun Oct 23, 2005 10:14 pm Post subject: |
after searching the site i tried setting it as a serial device with a 38400 baud and have gone through all of the ports that are availabel and it still cant be picked up, have also tried both a hard and soft reset |
alix776 Pocket GPS Moderator
Posted: Sun Oct 23, 2005 10:50 pm Post subject: |
what receiver is it _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Oct 23, 2005 11:26 pm Post subject: |
tomtom wireless GPS Mk II |
Posted: Sun Oct 23, 2005 11:48 pm Post subject: |
Is the GPS unit actually paired with the the PDA - it should show a couple of small green arrows under the icon (it needs to be SSP mode), once active and paired try setting the GPS in TomTom to other NMEA cabled devices, go for the correct Baud speed for your device, then select the correct bluetoth port from the options displayed (I know its a BT device and seems stupid selecting other wired - but give it a go) - finally make sure the GPS has a clean line of sight to the sky and give it ten min (minimum) to sinc up with the data (monitor the progress on the GPS setup screen you should see some activity after a while) - it will only need this ammount of time the first time, after this 20 - 30 seconds is about right - Mike |
Posted: Sun Oct 23, 2005 11:51 pm Post subject: |
no, thats the problem i cant get the Ipaq to even pick up the reciever so i can pair them |
Posted: Sun Oct 23, 2005 11:56 pm Post subject: |
Is the unit in discovery mode, most units do this for about a min. and it is this period you need to pair the device, it is usually put in this mode at start up so go for a pair at this point - once the pair is achieved the rest is easy - no pair and no sat nav I am afraid - but this highlights where the problem actually is - Mike |
Posted: Sun Oct 23, 2005 11:58 pm Post subject: |
i think the bluetooth may be screwed as it wont turn on anymore ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Sun Oct 23, 2005 11:59 pm Post subject: |
mikealder wrote: | Is the unit in discovery mode, most units do this for about a min. and it is this period you need to pair the device, it is usually put in this mode at start up so go for a pair at this point - once the pair is achieved the rest is easy - no pair and no sat nav I am afraid - but this highlights where the problem actually is - Mike |
i try to find the device using the guide linked to in my first post |
Posted: Mon Oct 24, 2005 12:00 am Post subject: |
Check PM
Mike |
Posted: Mon Oct 24, 2005 12:04 am Post subject: |
Is it rechargable, or does it take batts, replace/ recharge if necessary they don't generally die that easily, once up and running we can carry this on - Mike |
Posted: Mon Oct 24, 2005 12:06 am Post subject: |
the reciever is rechargeable but is fully charged as is the Ipaq |
Posted: Mon Oct 24, 2005 12:09 am Post subject: |
Is there a reset button recessed on the case for the stylus to prod, if not then its possibly taken a trip skywards - unusal for a new device |
Posted: Mon Oct 24, 2005 12:15 am Post subject: |
the Ipaq is about 2months old and the GPS reciever was bought today, yes there is a reset button and i have performed a soft reset and a hard reset multiple times |
Posted: Mon Oct 24, 2005 12:22 am Post subject: |
Does the PDA actually see the device at all (turn the GPS unit off then back on before trying this bit) - when in search mode, the explore BT Devices should spin the blue icon top left and then find the GPS unit, at this point select it, retrieving services will be displayed - at this point you select SPP mode, followed by finished. then the icon that is displayed needs to be tap and hold, then select connect from the pop up box, at this point you should get the two small green arrows and can then use it in TT - Mike |
