Pocket GPS World :: View topic - humber
humber
humber
PostPosted: Thu Sep 15, 2005 7:26 am    Post subject: humber Reply with quote
hi, does anybody know if you use a compact flash gps receiver how do u set it up and what port setting does it use,if any?which one would be ok for a toshiba e750,thanks
StevenGourlay
PostPosted: Thu Sep 15, 2005 9:39 am    Post subject: Reply with quote
What software are you using?
If tomtom 5 you need to select other cabled NMEA and Baud 4800 then select the correct port should be easy to see CF_Generic or somthing like that. (that port will only show if you have the GPS in the slot).
Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool
humber
PostPosted: Thu Sep 15, 2005 9:51 am    Post subject: Reply with quote
hi, the software i am using is tom tom 3, also would you know if a wired tom tom gps receiver should both green lights(power supply end and gps end) come on when plugged in to the supply only the power supply comes on mine. do you think the gps receiver should light up when connected to the power even if the pda is not on the other plug,it is a power lead that feeds both pda and gps,thanks
StevenGourlay
PostPosted: Thu Sep 15, 2005 10:11 am    Post subject: Reply with quote
The GPS should give you a green light or flashing light, make sure the Rj11 is connected properly.
Regards
Steven Gourlay
humber
PostPosted: Fri Oct 07, 2005 7:27 am    Post subject: trying tt 5 Reply with quote
hi i have had no luck with tt3 so i am trying tt5 wired gps receiver, software installed ok, but when i plug in the power cable to the pda and gps i get a message saying "unidentified usb device" please enter device driver number or path(tt3 wired receiver),any ideas what this means thanks
22.063 (19 Jun 24)
