gg2000 Occasional Visitor
Joined: Dec 09, 2003 Posts: 20 Location: East Sussex, UK
Posted: Sat Sep 03, 2005 4:43 pm Post subject: How best to find my position after crossing the Channel |
Each time I cross to France via Euro Tunnel the GPS signal takes 10 minutes or longer to find my new location. I am normally miles down the A16 before I get any navigational guidance.
Is it best to turn the GPS off during the crossing or say remain stationary on entering France until it finds a signal. Alternatively is there a way of speeding it up by telling the GPS about my new location. _________________ TTGO 700 v6.15 External Aerial |
Posted: Sat Sep 03, 2005 4:58 pm Post subject: |
Remain stationary with the unit powered up and it should sync fairly quickly - driving off will only further confuse the device - i would expect two min max for it to fire up so long as the unit has a clean line of sight - cheers from mike in the pub |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Sat Sep 03, 2005 5:00 pm Post subject: |
Park up with a clear view of the sk,y then turn on your GPS, and then start TomTom. That should be the quickest way to acquire a fix. _________________ Kam |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Sat Sep 03, 2005 6:13 pm Post subject: |
Hi gg2000
I know that this note won’t help you, in fact it may cheese you off, However, some GPS devices get a first fix quicker than others. I have a BT338 and it is wonderful at achieving this task. As soon as I came out of the tunnel on the French side I turned the BT338 on and it got a fix way before the train stopped. When I returned to Dover (by ferry this time) it even got a fix before I drove off of the boat. As I said earlier, it depends on your GPS device. |
BodgerBaz Lifetime Member
Joined: Jun 12, 2005 Posts: 368 Location: Mörsdorf, Germany
Posted: Sat Sep 03, 2005 8:19 pm Post subject: |
Considering how long you have from emerging from the tunnel until you actually leave the train, could you not remove it from it's cradle and hold it against the window of the train ?
Then when you eventually start rolling down the train it may hold it's signal.
Different on a ferry because there is no line of sight until you exit the boat. I'd then park up until a signal was aquired. |
Thanks for your replies, I guess I knew in my heart it was probably my system. Might just be the trigger I need to update
BTW Mike mines a bitter
George _________________ TTGO 700 v6.15 External Aerial |
CalumLawson Occasional Visitor
Joined: Dec 03, 2004 Posts: 42 Location: Stockton on Tees
Posted: Sat Sep 03, 2005 8:27 pm Post subject: |
Hi gg2000
I likewise have had no problem, I have the TomTom wired GPS and had a fix like Trevor1234 within seconds of leaving the train without needing to park up. How's your signal and aquisition tiime the rest of the time?
Calum |
tomo1340 Regular Visitor
Posted: Sat Sep 03, 2005 9:14 pm Post subject: |
Travelling to ExpensiveDisney last month and crossing by ferry, I turned my unit on within a few mins of docking at Calais. It took at least 10 mins to get a fix, obviously because I was moving. Coming back I may have either left it on or turned it on as a priority when getting into the car, I can't remember, however it was up and running before I hit the down ramp. _________________ o2 XDA Stellar
TTN6
MOWE |
