anneb Occasional Visitor
Posted: Sat Aug 27, 2005 2:22 pm Post subject: Expnasion Sleeve on ipac 2210 |
I have a Brodit in car mount that powers my 2210. My question is if I fit an expansion sleeve will it still fit in the mount and get power
Regards Anne |
Posted: Sat Aug 27, 2005 2:46 pm Post subject: |
Anne, are you sure that you can get expansion sleeves for this ipaq, I thought about the only thing you can add to a 22xx unit that will stick out abit would be the larger capacity battery - What are you looking to fit into the sleeve, as the standard unit will hade CF and SDIO? - Cheers Mike |
Posted: Sun Aug 28, 2005 12:47 pm Post subject: |
To be honest I didn't know you couldn't till I checked this morning. I got a book out of the library which had all this stuff you could add on and I assumed all pda's were the same.
I was hoping to add a gprs card but I have my gps stuff on the CF card, I had all sorts of errors when I ran it through the SD slot
Thanks for the reply
Anne |
Posted: Sun Aug 28, 2005 12:58 pm Post subject: |
If you need internet access (I assume you want that if you going for GPRS card), why not connect up to your mobile phone via bluetooth, just watch out for the tarrif costs - they can be expensive, I used to do this with the 4700 and my Nokia, but now I don't bother as the XDA is seamless - just switch it on.
There was a device on the market to convert a PDA into a phone that went into the CF slot - but it wouldn't work with PPC2003SE and cost a fortune.
If you want to get the TT onto SD - try a decent high speed card the 2210 has lots of "performance" related issues on this forum with respect to the SD slot. Mike |
alix776 Pocket GPS Moderator
Posted: Sun Aug 28, 2005 1:56 pm Post subject: |
tt seam ok on an sd card with the 2210 but to be sure id use a cf card andn connect to to phone via bluetooth usually ive found that a gprs bundle will work out much cheaper than pay as you go gprs
the other month i 10mb on my sda and it came to 42 quid 8O 8O 8O 8O
i now have a 12mb bundle for 10-15 quid a month
with o2 i managed to get a wopping 50mb per month for 4 pounds as part of a sim only tarriff deal _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
