freak Occasional Visitor
Posted: Thu Sep 01, 2005 4:57 pm Post subject: installing tomtom maps |
I have installed the setup disc successfully and i want to install some maps.
However, when i insert disc 1 (map disc not setup disc) and tried running setup, it keeps giving me the option to install the application only not to load the maps.
i tried extracting the map files .cab and it installs just fine BUT it will only install to main memory 'my documents' and i want it to be in my SD card.
any clues? |
lbendlin Pocket GPS Staff
Posted: Thu Sep 01, 2005 5:29 pm Post subject: |
You can use CabInstl to force the install to storage card.
However it sounds like your CD may be corrupt, and you should ask TomTom (or whereever you bought it from) for a replacement. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Sep 01, 2005 5:39 pm Post subject: |
thanks for the quick reply!
what actually should happen if i insert the first map disc?
does it have the option to load maps only?
thanks |
Posted: Thu Sep 01, 2005 5:52 pm Post subject: |
The first disc contains both the setup suite and some maps. So you should see the full menu on disc 1 and the map selection menu on all other discs. _________________ Lutz
Posted: Thu Sep 01, 2005 6:21 pm Post subject: |
dang..i guess i have to call tomtom and have them exchanged my discs.
thanks! |
