Braveheart252 Occasional Visitor
Posted: Wed Aug 24, 2005 10:02 pm Post subject: tom Tom Go 500 - set up problem |
I set up my Go 500 hardwired in my car and it works fine. Somewhere I have set it to only go to night screen when my headlights are on. This doesnt work so bright day screen at night. How do I remove this option so I can switch manually? |
TuurG Frequent Visitor
![](modules/Forums/images/avatars/350681644c94264ae694.jpg)
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Aug 24, 2005 10:06 pm Post subject: |
in Docking preferences, i believe that menu option is in screen 5 or 6 of the preferences menu. |
rkm_hm Frequent Visitor
![](modules/Forums/images/avatars/gallery/web.jpg)
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Wed Aug 24, 2005 10:12 pm Post subject: |
Change preferences / Docking preferences / Link night view to headlights
HTH. _________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
Posted: Wed Aug 24, 2005 10:37 pm Post subject: |
Excellent...soved many thanks!!!!!!! |
Posted: Wed Aug 24, 2005 10:52 pm Post subject: |
Good.
When you refer to 'hardwired' are you using the optional (and expensive!) car installation kit? If so, if this is correctly installed it should have connections to the headlights (for the purpose you mention) and to the radio (for muting).
If you're just using the standard mount - but hardwiring the power rather than using the cigar lighter socket - it doesn't do any of these things. _________________ Roger
TomTom via135
Posted: Thu Aug 25, 2005 9:43 pm Post subject: |
rkm_hm wrote: | Good.
The connection to the headlights goes via the ISO connectors. If the wiring loom of your car does not have the headlights connected to the ISO connector, then it will not work. |
