Pocket GPS World :: View topic - Help - dead TomTom
Help - dead TomTom
slast
PostPosted: Wed Aug 24, 2005 11:03 pm    Post subject: Help - dead TomTom Reply with quote
Working fine a couple of days ago, just tried to turn it on prior to departing for France at 0330, - nothing happens! No power light on with either computer feed or car adapter.... any ideas??
Steve
sgould
PostPosted: Wed Aug 24, 2005 11:15 pm    Post subject: Reply with quote
Green power light should come on if you have power.
Sometimes it can discharge when you think it's switched off, especially if you let it switch off with the ignition.
What colour fuse is in the charger lead? If it's purple, try and check the output voltage - this is the early model and sometimes fails and gives a fatal 12v to the Go instead of 5v.
If you have a white /clear fuse, just check the fuse. These chargers seem to be OK. But again see if you have any voltage at all at the output.
The charger is the only source of power. There is no power supplied to the GO via the USB computer lead.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps
Old_Phil
PostPosted: Wed Aug 24, 2005 11:16 pm    Post subject: Reply with quote
Check output of car adaptor - if it's 12v then you have fried your GO.
If 5v, then perhaps on/off switch has jammed. Try removing the fascia and re-fitting. My GO classic did this once and has been fine since. In fact, check that out first - it's an easy fix.
Otherwise, sounds terminal....
GO 700 App 6.520 WE Map v568.0
"If anyone tells you that retirement is harder work than working, listen to them - they ain't kidding!!"
slast
PostPosted: Wed Aug 24, 2005 11:39 pm    Post subject: Reply with quote
thanks guys, will try those ideas - power should be correct voltage as it's the TomTom original charger and worked fine previously.
Steve
slast
PostPosted: Wed Aug 24, 2005 11:48 pm    Post subject: Reply with quote
OK. seems like it is a poor connection in the adaptor, the green light on that is intermittent but it does produce 5V when ITs light is on, and then we are back in business so it looks like it was a flat internal battery.
Thanks for the advice, saved me a lot of cursing and getting lost tomorrow!!
Regards
Steve
22.064 (26 Jun 24)
