gripp Regular Visitor
![](modules/Forums/images/avatars/3602328439090bb506e3.jpg)
Posted: Tue Aug 23, 2005 9:31 am Post subject: Mitac 168 & TTN5 - which GPS port |
Which is the correct GPS connection option for the Mitac 168 and TTN5?
I have been using "Tom Tom Cable GPS" because this is the only one that worked when I bought and loaded TT last week, and I've successfully completed several journies using this configuration.
I now find I can get an equally good connection using "Other cable NMEA GPS" on "Serial Cable on SP2".
Can anyone advise which is the correct/best GPS connection for the Mitac and TT5?
Thanks,
Geoff. _________________ Nokia E65 & TT Nav6 |
GDW Occasional Visitor
Posted: Tue Aug 23, 2005 10:06 am Post subject: |
We use...
Other Cables (NMEA)
4800
Serial Cable SP2 |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Aug 23, 2005 12:17 pm Post subject: |
They both seem to work ok, Other Cable (NMEA) - Baud 4800 - Serial Cable on SP2 is the normal way as it's not a TT product, have tried both with no problems, so just leave alone if working ok. |
Posted: Tue Aug 23, 2005 12:20 pm Post subject: |
Thanks - I seem to get the same number of satellites whichever I choose, so I will leave well alone!
Posted: Tue Aug 23, 2005 12:30 pm Post subject: |
Hi Geoff
When I said leave alone, I was only kidding, the one great thing about a Pocket PDA is that you can set it up working OK then do a FULL Backup and start playing with all the settings, once you have got it frozen, a quick hard reset and restore and all is back to normal in just a few mins, well hopefully. |
Posted: Tue Aug 23, 2005 12:44 pm Post subject: |
Yes, I use Sprite backup reguarly and it certainly came into its own recently when the Mitac was sent away for the repair of a broken base connector. Obviously I did a hard reset before despatching it so as to remove all personal data.
I was back up and running within a few minutes with all my previously installed programs when the Mitac was returned with new motherboard & battery (courtesy of GlobalPositioningSystems). Incidentally, since I've the new mobo and battery the Mitac needs far fewer resets (side proddings) and the Sandisk WiFi card works better too. _________________ Nokia E65 & TT Nav6 |
