Pocket GPS World :: View topic - 520 PROBLEM WITH CAMERA DATABASES
BOXER
PostPosted: Wed Aug 24, 2005 11:17 am    Post subject: 520 PROBLEM WITH CAMERA DATABASES Reply with quote
I HAVE JUST INSTALLED THE CAM INFO ONTO MY SONS PIN 570 WITHOUT PROBLEMS BUT WHEN I DID THE SAME FOR MY 520 AT FIRST THEY DID NOT SHOW ON THE 520 SCREEN.I HAD TO USE EXPLORER TO MOVE THE CAMERA FILES FROM THE NAVMAN/PROGRAM FILES/MYPOI FOLDER TO THE SAME PLACE BUT ON THE SD CARD BEFORE THEY WERE VISIBLE ON THE NAV 520.
ALSO I HAVE NOTICED THAT ON MY SONS PIN 570 IT WARNS YOU OF A CAM APPROACHING AND ONCE YOU HAVE PASSED THAT CAM IT LOOKES FOR THE NEXT ONE ON YOUR ROUTE WHICH IS FINE BUT THE 520 WARNS YOU AS IT SHOULD AND GIVES YOU A COUNT DOWN IN FEET TO THAT CAMERA WHICH IS OK BUT ONCE PASSED IT THEN COUNTS THE DISTANCE FROM THE CAM YOU HAVE JUST PASSED WHICH WHEN TWO CAMS ARE NEAR EACH OTHER IS CONFUSING. IS IT SHOWING YOU HOW FAR TO THE NEXT ONE OR HOW FAR YOU HAVE GONE PAST THE PREVIOUS ONE. CAN ANYONE HELP?
Gee-Pee
PostPosted: Wed Aug 24, 2005 2:59 pm    Post subject: Cameras Reply with quote
A camera warning and count down to the camera will sound/shown at the distance you have it set up for. You can vary the distance in the Navman desktop software. After hou have passed the camera, the distance shown from the camera increases until you reach the 'distance setting' you have set. It is unusual to have cameras so close together that you are likely to confuse which one is being indicated unless you have set the distance at an unrealistic level.
PS Suggest you use the shift key on your computer and go to lower case unless you want to upset everyone in the forum! 8)
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
22.055 (29 May 24)
