Pocket GPS World :: View topic - Incorrect calibration on geotiff aerial photo
Charlatan
PostPosted: Thu Jul 28, 2005 11:06 pm    Post subject: Incorrect calibration on geotiff aerial photo Reply with quote
I'm trying to use a geotiff aerial photograph as a moving map on my imate Jam. I can convert the image and it shows on the PPC, but as soon as I connect the GPS, the background image disappears (goes white). I suspect that the coordinates are wrong.
I've downloaded the latest versions of Ozi for PC and handheld, and performed the following steps:
ON PC:
Import Map | Single DRG map. The tif in question has corresponding .tab and .tfw files in the same folder as the .tif.
I then converted the map using Img2Ozf, and copied it across.
On HANDHELD:
I can open the new map and see the background image, but as soon as I activate the GPS, the backround goes white. I do get the correct GPS reading in the top left corner (something like "-33.936905 18.466302").
I suspect that the coordinate system is incorrect - if I look at the map without turning on the GPS, I get coords like "-3757537.0000 -47399.000000" if i tap on the map.
Any ideas?
Charlatan
PostPosted: Thu Aug 04, 2005 2:53 pm    Post subject: Reply with quote
UPDATE:
I managed to get it almost right. I missed the projection options dialog box. Turns out I had to select Transverse Mercator, and change a couple of other settings for the zone (South Africa)
Now my E-W position is accurate, but N-S is about 50" out. Will play with it a bit more - must be a setting somewhere.
barryd
PostPosted: Thu Aug 04, 2005 7:26 pm    Post subject: Reply with quote
You could try asking in the Ozi Users newsgroup on Yahoo. This sort of question tends to get more response on there. (Apologies if you already have - I've not been there for a while myself).
http://groups.yahoo.com/group/OziUsers-L/
Barry Davies
22.101 (03 Oct 24)
