Pocket GPS World :: View topic - Brodit powered mounts - price differences?
chris123
PostPosted: Tue Aug 02, 2005 11:54 am    Post subject: Brodit powered mounts - price differences? Reply with quote
Can anyone explain the reason for the price difference between this fixed Brodit mount at £53.99
http://www.gpsforless.co.uk/product_details.php?id=963
And this one with a cigar lighter plug at £33.99
http://www.gpsforless.co.uk/product_details.php?id=931
I would have assumed that the only difference is the fitment of a cigar lighter plug? I want to do a permanent install, but am tempted to buy the cigar lighter mount and just cut off the plug and wire it in?
Chris
HP 614c
McGuider 7.54
Memory Map
PocketGPS speed camera database
PostPosted: Tue Aug 02, 2005 1:24 pm    Post subject: Reply with quote
The permanent install model has the 12v - 5v reduction circuitry in a module half way along the power lead, the other contains this in the cigarette lighter plug.
If you simply remove the cigarette lighter plug you'll end up frying your PPC as it'll be receiving 12v not 5v Embarassed
See Brodit #978606 and Brodit #968606.
chris123
PostPosted: Tue Aug 02, 2005 2:04 pm    Post subject: Reply with quote
Thanks Darren,
Definitely not something to find out the hard way Embarassed I presume the same is true of the equivalent amplified mounts.
It sounds like a pain having the converter in the cable though - I was planning in making a small (cable sized) hole through a hidden part of my dash - presumably the only way I can do this is to cut the cable between converter and mount, then remake it with the join behind the dash - assuming the cable is not detachable from the mount, and the converter is not too close to the mount to let me do this?
Chris
HP 614c
McGuider 7.54
Memory Map
PostPosted: Tue Aug 02, 2005 2:16 pm    Post subject: Reply with quote
It is a pain for such an install I agree, the simplest way would be to unsolder wth wire where it attaches to the sync plug at the base of the cradle, the connector is accesible by undoing two screws and the solder pads are on a PCB and large and easily worked on.
You could then feed the wire through the hole in the dash and re-solder. Simple enough.
chris123
PostPosted: Tue Aug 02, 2005 3:24 pm    Post subject: Reply with quote
Thanks again Darren,
Sounds straightforward enough - I wasn't sure if the cable connection at the mount end could be dismantled as you have described or was a sealed item.
One last question - I assume the same is true of the amplified mount?
Chris
HP 614c
McGuider 7.54
Memory Map
neil01
PostPosted: Wed Aug 03, 2005 4:52 pm    Post subject: Reply with quote
There is also the possibility of wiring in an additional socket in a more convenient place.
chris123
PostPosted: Thu Aug 04, 2005 7:59 pm    Post subject: Reply with quote
Thanks Neil,
I did think about adding a new socket, but managed to drill a hole through the dash hidden by the curvature of the join between two panels, which ahs worked out quite neat.
Chris
HP 614c
McGuider 7.54
Memory Map
22.071 (03 Jul 24)
