Pocket GPS World :: View topic - cant delete ttn3 favourites
transit
PostPosted: Wed Jul 20, 2005 4:56 pm    Post subject: cant delete ttn3 favourites Reply with quote
hi guys,i realy nead to delete some of my ttn3 favourites but cant.when i tap and hold on them i get the circle of dots but then they dissapear and it just navigates me to that particuler favourite withoout giving me any options(delete,move,edit etc).is there another way of deleting them(using activesinc maybee)dont realy want to reinstall tom tom3.
thanks ian
tom tom one classic v4
Robin2
PostPosted: Wed Jul 20, 2005 5:07 pm    Post subject: Reply with quote
You can't delete them. The less frequently used go down to the bottom of the list, and when you have reached the maximum number (I think it's 50) the ones at the bottom get deleted when you add new ones
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
cliffybc
PostPosted: Wed Jul 20, 2005 5:08 pm    Post subject: Reply with quote
Try Tapping Find (2nd Screen) , then tap Favourite. Tap the favourite you no longer want, then tap Edit Favourite.When you delete the name , the favourite disappears from the list.
Cliff
Ipaq 2210,
Rom 1.10.07
Byestor 512 hi-speed sd,
Kingston 512 cf
Tom Tom 5.0
BT GPS
transit
PostPosted: Wed Jul 20, 2005 6:35 pm    Post subject: Reply with quote
Cliff
hi m8 have tried that but when i tap i get no options at the favourites screen so i cant edit or delete,i just get the circle of dots as i tap and hold but no options it just starts navigating after a couple of seconds to the favourite as if i had just tapped and not held down(which i have)dont realy know what to make of it as its worked in the past?
cliffybc
PostPosted: Wed Jul 20, 2005 11:25 pm    Post subject: Reply with quote
hi, just to check are you tapping FIND then favourite rather than Navigate To then favourite? I have just tried it again and I have no problem deleting any of my favourites. Incidently I don't have a route set nor my gps unit switched on.I don't know if that will make a difference. When I do the above I get a screen with 6 choices
1.Edit favourite
2.Add as POI
3.Add to itinerary
4.Nearby points of interest
5.Reset gps for this location
6.Set as departure.
Follow my original instructions then confirm you can see this screen.
Regards Cliff[/u][/b]
Ipaq 2210,
Rom 1.10.07
Kingston 512 cf
Tom Tom 5.0
BT GPS
transit
PostPosted: Thu Jul 21, 2005 10:28 am    Post subject: Reply with quote
hi cliff
thanks for your help,i was indeed navigating to instead of finding,pretty sure this wasnt the way i used to delete but have followed your instructions and this way works a treat :D
thanks ian
cliffybc
PostPosted: Thu Jul 21, 2005 11:37 am    Post subject: Reply with quote
No problemo -glad to help
regards Cliff
Ipaq 2210,
Rom 1.10.07
Kingston 512 cf
Tom Tom 5.0
BT GPS
LiveLifeGoJump
PostPosted: Wed Jul 27, 2005 11:37 pm    Post subject: Reply with quote
Can't be sure as I've not got TTN3 on my PPC now but if I remember correctly you switch to favorites then tap & hold on the one you want to delete & a sub menu comes up.
I know I had no probs deleting favorites I had set when I was learning to use it.
Same method was used to delete itenary items.
If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE
