ClockworkCar Occasional Visitor
Posted: Mon Jul 04, 2005 1:50 pm Post subject: Maximum number of POI on TTM5?? |
does anyone know if there is a maximum number of POI allowed on TT Mobile5?
I have added quite a few POI's, but only 82 catagories are listed in the POI menue. When I delete a catagory, one of the 'hidden' (installed) catagories appears in it's place.
Is this a bug in TTM5, or am I doing something wrong? Is there a work-around??
Any advice appreciated.
Thanks. |
lbendlin Pocket GPS Staff
Posted: Mon Jul 04, 2005 2:02 pm Post subject: |
The number of POIs is only limited by the available memory. custom POI categories however are limited to 39 or less, depending on the platform and build. (recently TomTom have introduced a bug in the GO 5.2 software limiting this to 25 or so.)
Workaround: combine your custom POIs into fewer categories. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
aliendad Frequent Visitor
Posted: Mon Jul 04, 2005 2:20 pm Post subject: |
other situation is, on the nokia 6600 to many poi's will slow it down |
Posted: Tue Jul 05, 2005 12:08 am Post subject: |
Thanks for the answer lbendlin - I can just about live with 39 catagories (I certainly couldn't live with 25 !!) As you suggested, I'll need to learn how to use them to the best.
Aliendad - I'm running TTM5 on a 6600 too - what is the maximum number of POI that can be displayed without slowdown - and would you say the slowdown is significant/distracting? I'm still over awed with the system and have nearly all the POI turned on!
Thanks for your input guys :D |
Posted: Tue Jul 05, 2005 1:39 am Post subject: |
If you use proper tools to create the OV2 file (read: if you use MakeOV2) there is no theoretical limit to the number of POIs, and performance should degrade gracefully. If you just use a plain text file (without type 1 records) then yes, performance will be bad. _________________ Lutz
Posted: Tue Jul 05, 2005 9:30 am Post subject: |
ClockworkCar wrote: | Thanks for the answer lbendlin - I can just about live with 39 catagories (I certainly couldn't live with 25 !!) As you suggested, I'll need to learn how to use them to the best.
the slow down i have noticed is the startup takes longer, but i have all the camera / red light poi's excluding continental, sorry didn't count though how many others are in view |
-Bazza- Occasional Visitor
Posted: Sat Jul 09, 2005 12:46 am Post subject: |
aliendad wrote: | ClockworkCar wrote: | Thanks for the answer lbendlin - I can just about live with 39 catagories (I certainly couldn't live with 25 !!) As you suggested, I'll need to learn how to use them to the best.
Yes the startup time increases quite a lot if you have a lot of POIs. Just timed mine, it took 29 seconds. _________________ Nokia 6600 running TT Mobile 5.0 |
