Pocket GPS World :: View topic - Installing additional Maps in TTN 5
brianleach
PostPosted: Fri Jun 17, 2005 10:26 am    Post subject: Installing additional Maps in TTN 5 Reply with quote
I have loaded GB Plus, GB Postcodes and France Plus on a 1gb storage card in my o2xdaII.
I am now having trouble loading other maps although there is still a lot of space on the card.
The setup works as far as me allowing zonealarm to permit access to the pda.
It then sometimes comes up with an unknown architecture error message or otherwise just stops installing.
It is however still running because if I try to run setup again it will not run until I cancel the setup through the task manager.
Any thoughts please anyone.
Many thanks
Brian Leach
barleymo
PostPosted: Fri Jun 17, 2005 5:03 pm    Post subject: Installing maps Reply with quote
Have you tried installing the map to a folder on your PC and then coping it to your card. I find this much quicker to install maps.
Robin2
PostPosted: Fri Jun 17, 2005 5:09 pm    Post subject: Reply with quote
I always find it much more reliable to install maps using a card reader. You can buy a decent reader for about £10 and I have never had a failure when loading
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
trevtyler
PostPosted: Fri Jun 17, 2005 6:42 pm    Post subject: Reply with quote
Only had my TT5 for less than a week, so I may be wrong, but you only need to install one plus map (these contain the major roads of Europe) the rest of you maps if installed without the "plus" will save you space on your card.
Trev
brianleach
PostPosted: Mon Jun 20, 2005 4:33 pm    Post subject: Installing additional maps in TTN5 Reply with quote
Thanks barleymo. As you say this way is much quicker and also gets over the transferring problem I was having.
Thanks for this Robin2. I'll bear this in mind if I have further problems.
Thanks trevtyler. I think you are right about the plus maps. As I'm now using two 1gb storage cardsI have Iberia plus on one and Italy plus on the other. I'm installing the plain maps for other countries.
Brian Leach
22.063 (19 Jun 24)
