sunilc Occasional Visitor
Posted: Fri Jun 10, 2005 4:10 pm Post subject: Holux GR-231 with TT5 |
I've just upgraded from Tomtom 3.07 to 5. The GR-231 was working perfectly with my imate jam. Since upgrading I'm having the same issue many others are having with other receivers- "No gps device". I've selected other NMEA cable device, tried the various baud rates but still get nothing! Has anyone used the GR-231 with TT5? Any help would be greatly appreciated.
Sunil |
ROBBINS Regular Visitor
Joined: Dec 04, 2003 Posts: 82 Location: Worcestershire
Posted: Fri Jun 10, 2005 7:48 pm Post subject: |
Me Too - Just cant get my Holux 230 to work with TT5.
Should I leave BT Reg Tweak or remove.
Any help would be appreciated
Robbins
IPAQ 2210 Rom Upgrade 1.10
TT3 Upgrade 3.07(442) & GPS Upgrade 3.07(417/421)
GPS GR230 – NMEA0183V24800
Bluetooth Serial Port Com8
Or GM270 using CF card slot.
CheckPOInt 2.0.2.0
Active Sync 3.8.0 Build 5004
BT Reg Tweak 1.4 by 747
Sandisk CF Card Ultra II 1.0 GB
Transcend SD Card 256 MB
Sprite Backup 3.1.4 Build 2412
Brodit Active Holder with built in speaker |
Quantum Frequent Visitor
![](modules/Forums/images/avatars/76041576644e0c2c07d95a.png)
Joined: 16/02/2003 03:21:58 Posts: 285 Location: Seattle, Ecotopia
Posted: Sat Jun 11, 2005 2:26 pm Post subject: |
Sounds like the baud rate/com port problem. Any idea what these were set to in 3?
If all else fails, select Other Wired GPS, and set the BT com port and baud.
My brother has a Jam. Is this an Arm device, and can the regular TTN5 install in it? Any conflict with the bluetooth headset? |
barryd Frequent Visitor
Joined: Mar 27, 2004 Posts: 285 Location: Cheshire, England
Posted: Sat Jun 11, 2005 3:44 pm Post subject: |
Got my GR-230 working fine with TT5. I've since started playing with GPSGate, so have changed the settings again, but from memory it went just so...
Connect to the GPS first using Bluetooth Manager. (Tap Bluetooth icon at bottom right, then double-tap on the Holux GR-230 icon).
In TomTom I then used what I think were these settings:
GPS type - the one that shows a picture of the Holux GR-230.
Port - There are two Bluetooth ones in the list and you can't see the critical bit, the port number, as it's off the right edge of the screen. Oddly enough it turned out that the one you want - COM8 - was the first of the two, and the other one (COM5) was second.
Speed - I chose 38400. _________________ Barry Davies
