Pocket GPS World :: View topic - Hi-204e Problem : NO First Fix !
gjai
PostPosted: Tue Aug 10, 2004 10:37 am    Post subject: Hi-204e Problem : NO First Fix ! Reply with quote
hi,
First, sorry for my English, I 'm French....
Yesterday i'm received my gps hi-204e, ... after having read manual , I connected gps receiver to my pda, dell axim 3xi.
Wait 20 min for the Time to First Fix .... and LED indicator continues flashing !!!!!!!!!
No sat , no tracking.
I also tested on my laptop, IBM 570e, but it is similar....
After six hours of exterior 's test, my gps is always with 24°N/121°E... no fix , no sat ,.... and time passes...
This morning ,I 've to contact HAICOM and my retailer, i wait an answer .
Please Help me ... Laughing Out Loud
...If not, the mouse will return to it ...
Dell Axim 3xi + Haicom Hi-204e GPS = no sats :p
View user's profile Send private message Visit poster's website MSN Messenger
hackmaster
PostPosted: Wed Mar 23, 2005 2:05 pm    Post subject: HI-204E Light constantly on! Reply with quote
Hi Guys
Some help needed....
I have a IPAQ H5550 + HI-204E + TomTom3
it was working fine and i was well happy with it, whne it was working the light (red) would flash to indicate conectivity with satelites i presume.
it now does not work... the red light is constantly on and does not detect anything, says GPS position unrelaible...
im stuck as to wot to do...
help required please !!
CHR15
PostPosted: Wed Mar 23, 2005 7:30 pm    Post subject: Reply with quote
Have you guys tried the RESET FACTORY DEFAULT in the Haicom Viewer Utility?
Or a COLD RESTART in the same utility.
Also Query the firmware Revision to see if you can communitcate with it.
hackmaster
PostPosted: Thu Mar 24, 2005 11:39 am    Post subject: Reply with quote
Sorry im a little new to this hardware, but not sure how I am able to do this? connect it to PC then? connect to IPAQ then reset?
your help is great thanks
Skippy
PostPosted: Thu Mar 24, 2005 12:24 pm    Post subject: Re: Hi-204e Problem : NO First Fix ! Reply with quote
gjai wrote:
Wait 20 min for the Time to First Fix .... No sat , no tracking.
A first fix from factory defaults should take less than 20 minutes in good conditions. After the first fix, it should be able to cold start in less than 1 minute.
Sorry to ask silly questions, but:
Are you outdoors in a place where your receiver has a GOOD view of 75% of the sky in all directions (not obscured by buildings, trees etc)?
If you are using the GPS in your car, does your car have a heat reflecting windscreen which is blocking the GPS signal?
Gone fishing!
scubakid
PostPosted: Fri Apr 22, 2005 12:20 pm    Post subject: Reply with quote
If it is "flashing" it has a fix
make sure you have the correct com port set up etc to comunicate with it.
John
