Pocket GPS World :: View topic - HI-204E Red Light constantly on!
hackmaster
PostPosted: Wed Mar 23, 2005 2:06 pm    Post subject: HI-204E Red Light constantly on! Reply with quote
Hi Guys
Some help needed....
I have a IPAQ H5550 + HI-204E + TomTom3
it was working fine and i was well happy with it, whne it was working the light (red) would flash to indicate conectivity with satelites i presume.
it now does not work... the red light is constantly on and does not detect anything, says GPS position unrelaible...
im stuck as to wot to do...
help required please !!
NatSav
PostPosted: Wed Mar 23, 2005 7:34 pm    Post subject: Reply with quote
This problem caught me out when I first got the Haicom
It seems to happen when the Ipaq has been swithed off for more than 3 days, the haicom looses its charged power and thus forgets where the satellites are located.
What I tend to do is either run the gps utility program found on the cd that came with the haicom, or the free navigator prog located in the downloaed section pf this web site. this sort of wakes up the GPS, or unplug the haicom from the ipaq whilst switched on then plug back in again, not sure if this is approved but it works for me.
This above problem is the only bug bear with this great gps which i have taken on 2 good length hikes and it hasn't let me down once.
Only thing to be careful of is it can easily slip out of the CF socket if you are not careful, and yep its ugly!!!....but it works
HTH
Nat
hackmaster
PostPosted: Thu Mar 24, 2005 11:37 am    Post subject: Reply with quote
Thanks for getting back to me,
I apologise im a little new to all this and not sure what you mean when you say to try the tools on the cd... do i install them to the IPAQ and do this?
I did try to unplug the GPS Reciever whilst still conntected and waited for a while but still the red light remains... arrghh really p*ssed me off as it has usually been EXCELLENT on long journeys and saved me time and effort when I get lost!
I will take a look at the programs/tools available and see if they are installable on the IPAQ if so i will try what you suggested.
This one connects to the small port at the bottom, my unit is the small blue GPS 'mouse' and it sits on the dashboard, Is there such a device that connects to the compact flash? that would be great,
Thanks again
22.071 (03 Jul 24)
