Pocket GPS World :: View topic - How to Change Format of POI Edit asc file
jjc
PostPosted: Sat Feb 19, 2005 4:20 pm    Post subject: How to Change Format of POI Edit asc file Reply with quote
The asc files created by POI Edit are in the format LAT,LON,NAME; unfortunately NAVIO expects NAME,LAT,LON; is there a way to change the format of the asc file produced by POI Edit ?
thanks;
PostPosted: Sat Feb 19, 2005 5:01 pm    Post subject: Reply with quote
Yes, import into Excel, move the column around to the right order and then re-save as a CSV file.
If Navio was smart it would interpret the headers and allow you to select the correct order.
jjc
PostPosted: Sun Feb 20, 2005 10:40 am    Post subject: This solution does not work Reply with quote
This does not work because Excel changes the format when resaving; for example it puts 3 times the double-quotes instead of keeping one with the name; yes Navio could be smarter, POI Edit as well could allow to select the order of the columns;
other ideas ?
DavidW
PostPosted: Sun Feb 20, 2005 11:56 pm    Post subject: Reply with quote
You'll probably have to do a two stage process - use Excel to reorder the columns, then something like Notepad to sort out the quotes.
The other alternative is to use a programming language like perl to rearrange the fields, but this is not a beginners solution. If you have the language skills, you should know how to do it.
dnote
PostPosted: Mon Feb 28, 2005 3:26 pm    Post subject: Reply with quote
I will put it on the PoiEdit todo list...
22.071 (03 Jul 24)
