gstenson Frequent Visitor
Joined: 23/10/2002 09:53:59 Posts: 267 Location: Lincolnshire, UK
Posted: Fri Jan 07, 2005 5:40 pm Post subject: questions on display |
A few questions on TTM
1) When in the normal navigation mode, none of my POI appear. Is this by design? If it is, why? This seems daft?
2) Both the road displayed in the top right and right at the bottom are always the same - ie the road you are about to turn onto. Why isnt one the road you are currently on and the other the one you are about to turn onto?
3) On the summary display which is shown when you are over a certain speed limit, the bottom characters are off the screen - is this 'by design' also?
Thanks _________________ Audi S4
HTC One M8 & CamerAlert |
Darren Frequent Visitor
Posted: Fri Jan 07, 2005 6:01 pm Post subject: |
Are the POIs enabled in the POI menu?
The map display should show both the road you are on as well as intersections you approach. The bottom of the display always shows the road you are currently on.
I haven't observed the issue you detail regarding the safety screen view but will take a look! _________________ Darren Griffin |
Posted: Fri Jan 07, 2005 6:04 pm Post subject: |
Darren wrote: | Are the POIs enabled in the POI menu? |
Yes I have enabled them in menu 5-4
Darren wrote: | The map display should show both the road you are on as well as intersections you approach. The bottom of the display always shows the road you are currently on. |
It does but why does the display show right at the bottom of the screen (white text and blue background) the road you are going onto as well as the text in the top right behind a green background?
Darren wrote: | I haven't observed the issue you detail regarding the safety screen view but will take a look! |
Its not all the text but unless you look at the phone at an angle from the top of it the text is cut off at the bottom of the screen. _________________ Audi S4
Posted: Sat Jan 08, 2005 5:04 pm Post subject: |
Can anyone answer the POI issue? _________________ Audi S4
