Pocket GPS World :: View topic - Installing ukpostcode
ju9d
PostPosted: Wed Dec 15, 2004 3:56 pm    Post subject: Installing ukpostcode Reply with quote
I have problem installing UKpostcode into my Ipaq3970. After downloading ukpostcode and unzipping it. I tried to install it. However the installation seems to be incomplete - while retrieving data from the Ipaq, the process halt. I need some help to solve this problem. thank you.
SHADOW
PostPosted: Sun Dec 19, 2004 1:55 am    Post subject: Reply with quote
HI TRY WWW.DIGITOOLS.CO.UK......CLICK ON POSTCODE TAB AND FOLLOW INSTRUCTIONS....GOOD LUCK Thumbs Up
omaruk
PostPosted: Tue Dec 28, 2004 9:06 pm    Post subject: Reply with quote
do a soft reset of the ipaq, should be ok, make sure you have followed all the instructions on the digitools website to the letter
flygti
PostPosted: Mon Jan 03, 2005 9:06 pm    Post subject: Reply with quote
I read on their website that if you have checkpoint installed (or other TomTom addon) then the necessary interface files will already be installed on your PDA. In this case - you just need to copy the exe and dat file to a directory on your PDA and you can then run it... This is what I did on mine and it worked fine....
To make life easier you can create a shortcut to the exe file in the directory where you copied it and add it to the start menu...
22.064 (26 Jun 24)
