Pocket GPS World :: View topic - sprite backup
sprite backup
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
dunno
PostPosted: Wed Dec 08, 2004 5:03 pm    Post subject: sprite backup Reply with quote
i have a ppc ipaq 2210 and am trying to do a restore , but each and every time i do 1 ,the restore part works and it asks me to reset thats when it all goes haywire it resets does it startup and locks up at that point after the line is full and the only way to get rid of it is to do another hard reset
any help will be appreciated
DavidW
PostPosted: Thu Dec 09, 2004 11:08 am    Post subject: Reply with quote
Do you have any TomTom software installed, and if so, which version (especially of GPS)?
Which version of Sprite Backup are you using?
Version 3.1.3 of Sprite Backup, together with a recent version of TomTom GPS (3.0.7 is the latest at the time of writing) should have fixed any restore problems linked to the TomTom Bluetooth DLL.
If you have TomTom software on your machine, try restoring with the latest Sprite Backup then, if that doesn't work, restore without \Windows\ttbtdev.dll. If you do the latter, you really need to do some registry editing to sort out the Bluetooth stack afterwards - though removing (fully - it may have to be removed twice using Start Menu, Settings, System tab, Remove Programs before it has really gone) and reinstalling TomTom GPS may well work as an alternative.
dunno
PostPosted: Fri Dec 10, 2004 6:18 pm    Post subject: Reply with quote
hi i do have the latest tomtom setup but am using a sprite version 1.1.0.6 which came with the ipaq , i suppose because i am using a old version is causing the problem
thanks
dunno
PostPosted: Fri Dec 10, 2004 6:30 pm    Post subject: Reply with quote
got the download but can't uninstall the original sprite backup as it is not in my add/remove list (doubled/tripple checked) should i just install it and see what happens or is there another way to remove it
thanks
DavidW
PostPosted: Fri Dec 10, 2004 10:48 pm    Post subject: Reply with quote
You can install Sprite Backup on a machine with iPAQ Backup installed - the latter can't be removed as it's in ROM.
iPAQ / Sprite Backup 1.1.0.6 is rather old - there's been a lot of advances since that. There is a reduced cost upgrade for users who have iPAQ Backup built into their machine, which I would recommend highly.
As for your restore issue, the only option probably is to deselect ttbtdev.dll in \Windows when restoring - then uninstall and reinstall TomTom GPS in the hope that that tidies up any Bluetooth stack problems resulting from not restoring this DLL.
dunno
PostPosted: Sat Dec 11, 2004 12:12 pm    Post subject: Reply with quote
thank you for the replies , i suppose teh price is rather chap for all the hastle you have to go though ,so i might just buy it
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.063 (19 Jun 24)
