Pocket GPS World :: View topic - TT Freezes - locks up
Jacklad
PostPosted: Thu Nov 11, 2004 10:18 pm    Post subject: TT Freezes - locks up Reply with quote
New iPAQ received, installed TT3 (+3.07 upgrade) ... New Fortuna Clip On arrived (manual says v1.2) .. all fires up OK, and works a treat for a few minutes driving then the map freezes / locks.
Display shows it is still seeing sats .. but if you look under GPS, the Lat & Long are not changing - although the sat bars are shown in lock.
On the Fortuna the Blue light is on .. but has stopped flashing, and I have checked a few times it is happily bursting away up until if freezes and at that point just stays solid blue. (even if left for an half an hour)
If I switch off Fortuna and wait a few seconds and then switch back on .. often all works OK again without restarting TT3 .. but sometimes I have to restart the application.
I have removed and re-installed TT3 and maps just in case but still the same, am I safe in assuming the Fortuna is faulty, or is it not possible to tell from this.
I have been told that it could be the SD card .. a brand new Kingston 256Mb (bought Kingston to avoid cheapy makes).
Anybody suggest anything ? ...
SHC
PostPosted: Fri Nov 12, 2004 12:07 pm    Post subject: Reply with quote
I have the same problem. I had a perfect working system - ipaq 2210, TTN3 and Rikaline X7 Bluetooth.
Bought an ipaq 4700, and the problem started with TTN3 freezing. I tried installing maps on the CF card, the SD card. I defragmented as suggested it still happens.
I wonder if its anything to do with the lastest TTN upgrade??
sland
PostPosted: Fri Nov 12, 2004 1:39 pm    Post subject: Reply with quote
Try disabling the display of POIs to see if that helps. You can still navigate to them and checkpoint will still warn against them but just don't display them
Rgds,
Mike
SHC
PostPosted: Sun Nov 14, 2004 11:13 am    Post subject: Reply with quote
I have tried disabling POI, makes no difference. I have tried different versions of the GPS driver, I have re-installed everything. It still locks up. I am sure its something to do with the GPS driver because when the device freezes, GPS still shows satellites being received, If I the close TTN and restart then their is no signal being received at all until a soft reset is performed. (which is a bit hard to do when driving!)
Any more ideas?
sland
PostPosted: Sun Nov 14, 2004 11:53 am    Post subject: Reply with quote
Have a look here -> http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=12216&highlight=4700+patch to see if that helps?
Rgds,
Mike
SHC
PostPosted: Sun Nov 14, 2004 3:28 pm    Post subject: Reply with quote
Thanks for the link but I've had the patch described from day one. The only thing mentioned that I havent is to try the GPS driver 2.07 from this website, wasnt sure if it would work with TTN3. Might give that a go next.
Jacklad
PostPosted: Sun Nov 14, 2004 8:52 pm    Post subject: Partially Solved (at least moved to a diffrenet problem) Reply with quote
OK - an improvement ..
I tried somebody else’s SD card and also tried another Fortuna ... same problem - so looks like TT3 is the fault.
I removed TT, reinstalled a base install and then applied .03 upgrade.
Now it no longer freezes / locks up. NIG improvement.
However it runs for 5-10 mins, then the Bluetooth Browser window pops up asking me to choose a device ... once it has popped up it keeps reappearing at annoying but random intervals.
Sometimes as much as once a minute.
I have been advised that 'Bluetooth Tweak' a freeware utility may fix this, so will give it a go.
Jacklad
PostPosted: Tue Nov 16, 2004 6:51 pm    Post subject: Reply with quote
Installed "Bluetooth Tweak" and things are at last working.
Now instead of bringing up Bluetooth manger every few minutes, I just get a beep ... screen says GPS unreliable .. then another beep and it carries on.
At least it works.
Still less solid than I expected ... don't know whether this is Bluetooth or the GPS side.
(iPAQ has Bluetooth Manager 1.4.1 build 58 )
Jacklad
PostPosted: Fri Nov 19, 2004 12:03 am    Post subject: Reply with quote
Some more information - in case it triggers anything with those in the know.
Installed Bluetooth Tweak and much better ... each loss of synch, just a beep and back in a couple of seconds.
But still get the total loss of synch.
Today happened 5 times in a 350 mile round trip.
On 4 occasions I could restart by opening Bluetooth manager - I could see hat shortcut showed not connected .. tap/hold/connect re-established connection and TT3 carries on OK.
However on one of the occasions (and this has now happened several times) same symptoms .. but unable to re-establish connection.
Either Bluetooth manager goes into "waiting for device" or "unable to establish connection"
Only a soft reset will then recover form this.
When in this 'no signal mode' the Fotuna has a permanent 'on' Bluetooth LED (not blinking) the other 2 LEDs are green.
I have re-installed TT3 (applied 3.03 upgrade) and also re-installed the iPAQ Bluetooth driver.
Fortuna have confirmed I have the latest firmware.
Now had the set up for 3 weeks and not had it stable yet .... any ideas?
22.063 (19 Jun 24)
