nuttynicols Occasional Visitor
Posted: Wed Jan 19, 2005 6:08 pm Post subject: xda2 and tomtom3 nav help needed |
Can you help i have a xda2 which i loaded tomtom 3 navigator .
how ever i have tried connecting this and the tomtom say GPS DISABLED.
When i touch the screen a icon say "unable to lauch the gps control panel"
Please help if you can i we be grateful. |
andy1turner Occasional Visitor
Joined: Jan 11, 2005 Posts: 15 Location: South West Scotland
Posted: Thu Jan 20, 2005 11:32 am Post subject: |
Hi there
I'll try to help but I'm a relative newbie as well.
First check Tom Tom blue light is flashing and als that the green light flashes occassionally. I uderstand that the geeen light flashes as the GPS receiver gets a fix from a satellite.
Now make sure that Bluetooth is up and running on the XDA.
Now two ways to do the same thing.
In Tom Tom get to a map display. From the menu at the bottom select File, GPS Status.
You shoud get a GPS screen showing postiton etc. If this is all greyed select second tab and ensure that box at top left hand corner has a tick, if not touch it with stylus until a tick appears.
Other way is to go to Start menu, settings, GPS Status and do as above. You get to the same place but in two diferent ways.
I assume you are using the Tom Tom Bluetooth GPS receiver?
I have found this a little flaky at timesand sometimes a soft boot fixes these type of problems.
HTH
Regards _________________ Andrew Turner
I don't think that your bad planning is any reason for me to have an emergency! |
Darren Frequent Visitor
Posted: Thu Jan 20, 2005 11:47 am Post subject: |
It would help to know which GPS Receiver you have here. Not being able to launch the GPS Control panel suggests a re-install of the GPS Driver may be in order, insert the install CD and follow the prompts to re-install. _________________ Darren Griffin |
Posted: Fri Jan 21, 2005 2:13 pm Post subject: |
Sorry guys i have a tomtom none bluetooth gps satellite receiver
The gps has no signal and the program is in gray everything showing 0
the gps tab is ticked and on tomtom navigator gps
serial cable is on com1
the connecter that i use in the car says
ic-ipq38-grs x0100310 for ipaq
could i have the wrong cable |
Posted: Fri Jan 21, 2005 2:27 pm Post subject: |
Have you disabled 'receive all incoming beams' in Start | Settings - Connections/Beam ? If not you'll need to do so to allow access to COM1 on the XDA. _________________ Darren Griffin |
Posted: Fri Jan 21, 2005 2:47 pm Post subject: |
Hi there
I'll bow out now and leave you in Darren's tender hands. I'm sure he will be able to get you up and running.
Regards
Andrew |
