Omertron Occasional Visitor
![](modules/Forums/images/avatars/gallery/side_smile_b.jpg)
Posted: Wed Oct 06, 2004 12:04 pm Post subject: BT headset and navigation |
I'm looking at getting at BT headset (Specifically Jabra BT250 FreeSpeak Bluetooth Headset) and was wondering if I could use it to accept the output from Navigon on my PDA (iPAQ 5550) and then switch over, should the phone ring.
Does anyone know? Is there any options I should look for to enable me to do that?
Stuart _________________ TomTom GO 910 |
lbendlin Pocket GPS Staff
Posted: Wed Oct 06, 2004 1:40 pm Post subject: |
Technically it does work when your Pocket PC supports both Audio Gateway and headset profiles. In reality I had problems with my iPAQ 6315 already when just forwarding the audio to the headset (obviously I was running BT GPS at the same time). But this can also be due to the low specs of the 6315 (168 MHz processor) and the 55xx may well pull it off. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Dirk Occasional Visitor
Joined: 02/02/2003 10:56:21 Posts: 12 Location: Staffordshire (UK)
Posted: Thu Oct 07, 2004 8:40 pm Post subject: |
I doubt whether it is possible to switch from the pda to the phone before the caller hangs up... You first have to disconnect the headset from the pda and then reconnect it to the phone and that takes time.
I use the Jabra 250 with a Nokia 6310i phone and when the two have lost contact and someone calls me I generally don't have time to reconnect before the caller gives up.
Regards
Dirk. |
Posted: Thu Oct 07, 2004 8:47 pm Post subject: |
You don't need to switch from the PDA to the phone, because the PDA is the phone. It's more a question of "how many different Bluetooth services can the 6315 handle at the same time?" _________________ Lutz
Posted: Fri Oct 08, 2004 5:28 am Post subject: |
I have tried it with my Solteras Halo headset and TomTom Navigator 2.24 - without much success. Part of the problem is that the headset goes to sleep whenever there is no sound. And waking up takes some time, so the first part of the TomTom announcements always gets lost. After a few times the audio gateway seems to crash completely and TomTom will stop saying anything (routing does continue though, which is more than what Mapopolis does).
So in summary I think the audio gateway protocol is not yet suitable to run together with the SPP. _________________ Lutz
Posted: Sat Oct 09, 2004 12:03 pm Post subject: |
Thanks for the replies... at least it would save me hours of endless messing to come to the same conclusion ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ TomTom GO 910 |
Posted: Mon Oct 25, 2004 3:57 pm Post subject: |
For what it's worth - I found a workaround. What you need to do is "keep the line open" - play some of your mp3's in the background at low volume. This keeps the BT headset busy, and will allow you to hear the navigation commands (at a louder volume than the music). Has the nice additional benefit of some good music ;-) _________________ Lutz
mavis Occasional Visitor
Posted: Fri Oct 29, 2004 6:01 pm Post subject: BT headset |
You might find that this programme may help, althought i have not treid it myself.
Click here.
(Post edited to remove long URL) _________________ iPAq 2210
Navigon NM4
Navigon GPS with Bluetoth and TMC
Tom Tom car mount |
Posted: Fri Oct 29, 2004 11:09 pm Post subject: |
mavis,
that program will not help. The problem is not to get the BT headset profile running, but to keep the Audio Gateway profile from timing out. _________________ Lutz
