mupp Occasional Visitor
![](modules/Forums/images/avatars/2531121834a51eb63a167a.jpg)
Joined: 29/03/2003 21:33:51 Posts: 58 Location: Woking
Posted: Sun Sep 14, 2003 8:04 am Post subject: AA Battery carrier? |
Has anyone found a good, small, waterproof durable container that would hold two AA Batteries as a backup for my hiking gps?
Best I've found is a double AA clip from a model shop, but it leaves them open to moisture and has external contacts. Anyone found a better container or pouch, just something I can slip into my pocket? |
MikeB Frequent Visitor
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Mike.png)
Try looking at the Otterbox 1000 reviewed here http://www.pocketgpsworld.com/otterboxes.asp it may be a bit OTT for your requirements, but will certainly keep your batteries safe and dry. _________________ Mike Barrett |
Pc-Mobile Frequent Visitor
![](http://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Can you not just keep them in your pocket?
Or use a little polythene bag that you can "press and seal".
_________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
mduncombe Occasional Visitor
Joined: 19/08/2002 23:00:11 Posts: 12 Location: United Kingdom
I just wrap mine up in a bit of insulation tape or duct tape.
Mark |
Biv Occasional Visitor
Posted: Fri Jan 09, 2004 4:57 am Post subject: Good Cheap case |
I made one out of plastic pipe. Get the size you need and cut it to length and put solid caps on it. They usually fit pretty tight. You can glue one end if you want. ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) |
musika Occasional Visitor
![](modules/Forums/images/avatars/gallery/hand_neg.jpg)
Joined: 21/06/2003 18:48:13 Posts: 9 Location: West Midlands United Kingdom
Posted: Sat Jan 10, 2004 10:15 pm Post subject: |
Try here. Haven't checked it out.
It may be U.S. only, but it's a start.
http://tinyurl.com/2277m
m. |
dlegros Occasional Visitor
UKHABU Occasional Visitor
![](modules/Forums/images/avatars/396256414174f4790c9ac.jpg)
Posted: Mon Nov 01, 2004 5:04 pm Post subject: |
Maplins have any number of different battery holders for about 49p!! |
