Pocket GPS World :: View topic - Recommended POI Updates..
Sarjoo
PostPosted: Tue Sep 14, 2004 4:49 pm    Post subject: Recommended POI Updates.. Reply with quote
Folks, I noticed loads nice POIs the link from one of the other topics, and noticed that a lot of them are probably similar to the ones the TTG comes with.
E.g.
Petrol Stations, Railway stations.
Q1: Is it worth updating to these sorts of things, or are the default ones sufficient?
Q2: Does anyone know if the Postcode POI's are worth getting? Wat exactly do they do? E.g. the Central London Postcode POI.
Thanks!
bestyman
PostPosted: Tue Sep 14, 2004 11:16 pm    Post subject: Reply with quote
HI,
I would update them as they are better than the ones that come with tom tom go and you can use updates and pre instaled pois together . If you don`t like them just delete.
I would advise the same with the postcodes, install them and have a play , but what they do is allow you to search for a full postcode rather than the TTGOs short ones.
Regards
Mark
Oldie
PostPosted: Wed Sep 15, 2004 7:20 am    Post subject: Re: Recommended POI Updates.. Reply with quote
E.g.
Thanks!
If in Q2 you are referring to the George Spanellis Code Search files then you may like to have a look at my Windows PC program CodeSearch which is in the Downloads area http://www.pocketgpsworld.com/modules.php?name=Downloads&d_op=viewdownload&cid=22
The program makes it easy to extract a subset of postcodes and create a TT POI overlay which you can transfer to TT Go. I have no experience of using TT Go but using large OV2 files with TT3 on a PocketPC system is quite slow. Hence I wrote CodeSearch. If you also use TTN3 then Niels Thomsen's UKPostcodes program for the PocketPC is the one to use.
Sarjoo
PostPosted: Wed Sep 15, 2004 9:57 am    Post subject: Reply with quote
bestyman wrote:
HI,
..what they [Postcodes] do is allow you to search for a full postcode rather than the TTGOs short ones.
Thanks Mark,
So the postocde would be full codes but the mechanism is the same i.e. u choose city, then street, then full postcode?
Another thing is when you do a new route search, is there a way of by-passing the step where TTG asks you for the city/street name, and just setting the postcode as the destination?
22.094 (25 Sep 24)
