kostis100 Occasional Visitor
Posted: Tue Aug 24, 2004 1:44 pm Post subject: Garmin GPS 17N and Pocket PC ..... |
Can i use my Garmin GPS 17N
http://www.garmin.com/products/gps17n/
with .............. 1). (my old) HP iPAQ h1940 Pocket PC
and
with .................2). (my new) Acer n30 Pocket PC ?
Are there any cables for that ? |
lbendlin Pocket GPS Staff
Posted: Tue Aug 24, 2004 3:57 pm Post subject: |
It says in the tech specs that the device speaks RS232. So technically you can connect it to a COM port on a Pocket PC.
Now for the bad news. The 1940 doesn't have a COM port. (only USB). And - neither does the Acer!
So the only way you can accomplish this is to buy one of the serial GPS receivers that are specifically suited for the 1940 or the Acer (because their cable contains a USB to serial converter) , cut the cable and connect your Garmin instead.
Now wait, why would you do that when you have just bought a working combination? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Sep 13, 2004 11:03 pm Post subject: |
lbendlin wrote: | It says in the tech specs that the device speaks RS232. So technically you can connect it to a COM port on a Pocket PC.
Now wait, why would you do that when you have just bought a working combination? |
there is a serial cable for Acer n30 http://www.mobiledatadirect.co.uk/product_info.php?products_id=1522
............if i use it can i connect the Acer n30 with Garmin 17n ? |
Pc-Mobile Frequent Visitor
![](http://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Tue Sep 14, 2004 2:55 pm Post subject: |
Most likely you can.
I have not used/tested an Acer N30 so do not know what sort of com port it has.-- not all com ports are the same. If it has a true RS232 com port you should have no problem. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Tue Sep 14, 2004 5:42 pm Post subject: |
Pc-Mobile wrote: | Most likely you can.
I have not used/tested an Acer N30 so do not know what sort of com port it has.-- not all com ports are the same. If it has a true RS232 com port you should have no problem. |
what about the HP ipaq 2210 pocket pc ? can i connect it with Garmin 17N? do you have data( serial) and power cable ? |
Posted: Tue Sep 14, 2004 7:06 pm Post subject: |
I forgot to add that you do need a null modem adapter between the 2 serial cables.
We have cables for Ipaq 2210.
PQ8SMP is a "serial interface" which you can connect to a serial device like a GPS (connects to the PC serial cable of the GPS, no null modem adapter is necessary).
It also allows you to power the Ipaq with appropriate car adapter if you already have one. If not then add CKUC (car adapter/cable for use with PQ8SMP).
http://pc-mobile.net/pdaserial.htm _________________ Pc-Mobile
Posted: Wed Sep 15, 2004 8:18 am Post subject: |
can i found the cable in Europe ? |
Posted: Wed Sep 15, 2004 6:44 pm Post subject: |
kostis100 wrote: | can i found the cable in Europe ? |
WE ship to anywhere in the world, if that was what you meant. _________________ Pc-Mobile
