Pocket GPS World :: View topic - What if someone has to have their iPaq replaced three times?
Jammer
PostPosted: Sun Aug 29, 2004 1:47 pm    Post subject: What if someone has to have their iPaq replaced three times? Reply with quote
So, when they come to do their third install of the Tomtom software, they won't be able to do this because of the terms of use of the software?
If someone bought an iPaq (or any other PDA) and installed Tomtom.
Then had to have it replaced because it was faulty.
And then installed Tomtom again.
And then had to have it replaced because it was faulty.
Surely they will get stuck the third time?
Just wondering!
OM
iPaq 3870
Fortuna Clip On Bluetooth
Tomtom
London
Currently testing Fortuna to see if it's any good!
alix776
PostPosted: Sun Aug 29, 2004 2:04 pm    Post subject: Reply with quote
they would have to go to ttcode and if that didnt work email or ring tt support
where exactly are you you going with this thread
device Lumia 950 xl
Jammer
PostPosted: Sun Aug 29, 2004 2:27 pm    Post subject: Reply with quote
Well... firstly, I was just wondering! Smile
But... the situation might happen to me...!
I bought an iPaq and Tomtom unit.
I had all sorts of problems.
I've had to send the Tomtom unit back for exchange/repair at Tomtom.
I've used the software to install on another iPaq I have.
Now... if I still have my origianl problems... then I might have to have the new iPaq changed, since logic says that if the Tomtom kit is fixed the fault must lie with the iPaq.
If this did happen, then I would have to do a third installtion of the Tomtom software?
iPaq 3870
Tomtom
London
alix776
PostPosted: Sun Aug 29, 2004 2:30 pm    Post subject: Reply with quote
what problems are you haveing with the ipaq is just bt dropouts or its it lockups
device Lumia 950 xl
Jammer
PostPosted: Sun Aug 29, 2004 2:57 pm    Post subject: Reply with quote
Both.
This used to happen too regularly.
Any suggestions to solve this?
Also the Tomtom bluetooth unit used to take a loooong time to get a proper GPS signal. Hence when I spoke to Tomtom, they told me to send the unit back to them.
iPaq 3870
Tomtom
London
alix776
PostPosted: Sun Aug 29, 2004 4:02 pm    Post subject: Reply with quote
try gps2.07 uncheck receive incoming beams in the ir settings and in properties select the poi tab then right at the top uncheck show poi exit tt and hopefully that should do it if not try formatting you sd card using storeage tools available from the downloads section on this site reinstall the maps and away you should go
device Lumia 950 xl
Jammer
PostPosted: Sun Aug 29, 2004 4:16 pm    Post subject: Reply with quote
gps2.07? What's that?
ir settings? Where's that?
Sorry... am I being dumb? Confused
iPaq 3870
Tomtom
London
alix776
PostPosted: Sun Aug 29, 2004 4:36 pm    Post subject: Reply with quote
sorry gps 2.07 is the tt gps application if you have done all the updates
then youve probbly got gps 3.03 or 3.04 if you got the the downloads area of this site youll see gps 2.07 ir is the infrared port on the ipaq you can access this from the connections menu on the ipaq
device Lumia 950 xl
22.063 (19 Jun 24)
