JBR Occasional Visitor
Posted: Wed Jun 02, 2004 1:17 pm Post subject: CheckPOInt 3.2 Record POI Problem |
I am running CheckPOInt 3.2 and TTN 3 with wired GPS on an iPAQ H2210 and Windows Pocket PC 2003 Premium Edition.
It all works fine (most of the time!). However, I am unable to allocate a Button to CheckPOInts Record POI facility in order to record the location of cameras.
Within CheckPOInt's General Settings, I have allocated Button 3 - Calendar for Recording a POI and in TTN3 Properties, the buttons are all set to <Default function>.
However, whenever I press the Calendar button, guess what, Outlook's Calendar pops up! Whatever I do, I just can't persuade the Record POI menu to pop-up. There does not appear to be any other way of making this menu appear either.
Any ideas? |
BrummyGit Regular Visitor
![](modules/Forums/images/avatars/gallery/simpsons22.jpg)
Posted: Thu Jun 03, 2004 11:07 am Post subject: |
I had this problem, try using the contacts button instead as that one worked for me. |
Posted: Fri Jun 04, 2004 12:04 am Post subject: |
Many thanks for your suggestion, the Contacts button works! |
Whitey Occasional Visitor
Posted: Thu Aug 26, 2004 12:11 pm Post subject: |
Im having same issues with v3.2 on a
XDA II
Rom: 1.72.00WWE
Radio: 1.14.00
ExtRom: 1.72.126
using tomtom nav 3, with bluetooth gps
Basicly any key wont work to trigger a Record of a POI, ive even tried removing all Button controls , and just having Checkpoint with any of the 4 options and none work :S
anyone else have this or a idea ;)
cheers
(ps i aint ruling out user error here lmfao, but it aint rocket science is it) |
swing Pocket GPS Verifier
Posted: Thu Aug 26, 2004 12:55 pm Post subject: |
Whitey wrote: | Basicly any key wont work to trigger a Record of a POI, ive even tried removing all Button controls , and just having Checkpoint with any of the 4 options and none work :S
anyone else have this or a idea ;) | Firstly, the button only works when you are in Navigator mode, and you have a GPS signal, but assuming you have both of these correct, try the following:
In the PPC itself, assign a hardware button to CheckPOInt (I use button 1, but I guess it should work with any) - then use this same button within CheckPOInt for recording POIs. This works for me. |
Posted: Fri Aug 27, 2004 2:46 pm Post subject: |
Wayhay , works for a run down (must be here somewhere all this info )
Seems to only work under the following conditions on a XDA II
Gps connected and runing with GOOD data (anything else is pointless)
only works on CONTACTS button, ignore numbering in Checkpoint
Dont need to disable any STANDARD button controls
Cheers swing for pointing me in right direction ;) |
