hijacker Regular Visitor
![](modules/Forums/images/avatars/796487184490f720f0b6d1.jpg)
Posted: Sat Jul 17, 2004 9:57 pm Post subject: Are you using XTracV2 but can't get data to flow into TT3 ?? |
Does your ClipOn appear to have made a Bluetooth connection but no data is flowing through to TT3, Navigon etc...?
For me this applied for 2 different ClipOn's. Once just recently purchased with the latest Xtrac already on it and an older ClipOn that was flash upgraded.
When TT3 has loaded, you should see no activity in GPS STATUS. (Using driver NMEA 38400).
Goto to the Bluetooth Manager and you should see that despite the blue flashing light a bluetooth connection has not in fact been made, so make a manual connection and it will then ask you to input your passkey. Type this in ("0000") press enter and then your Ipaq will bond to your ClipOn and hey presto data flows through and continues to do so.
I've found this to work on two different Ipaq's (both 2210's) _________________ TT GO 1005 |
TC Regular Visitor
Joined: Oct 22, 2003 Posts: 121 Location: Wiltshire, England
Posted: Mon Jul 19, 2004 8:47 am Post subject: |
Hijacker,
I'm using a Clip-on that's been upgraded and it seems to works fine with TT3.
In Bluetooth Manager delete the Clip-on short cut and then go to paired devices and delete ClipOn-BTGPS. Now create a new connection and paring and I think you ill be OK
TC _________________ Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map |
gokhart Regular Visitor
![](modules/Forums/images/avatars/avatar_sp_035.jpg)
Posted: Mon Jul 19, 2004 5:40 pm Post subject: |
I have a 2210, but have not got this problem. Maybe it's the way you setup the initial connection/pairing ?? |
T_E_O Occasional Visitor
Posted: Wed Jul 21, 2004 11:47 am Post subject: |
Try using SiRF 38400 instead of NMEA, because in ST as well as in XT mode, the clip-on speaks SiRF, not NMEA. |
