Pocket GPS World :: View topic - Garmin Drive series
Garmin Drive series
spikem
PostPosted: Fri Oct 19, 2018 11:18 pm    Post subject: Garmin Drive series Reply with quote
If you have the UK / ROI version of a Drive assist series that only has voice control , will this change to voice command if you update the map to a full Europe version.
PostPosted: Sat Oct 20, 2018 10:03 am    Post subject: Reply with quote
Good question but no idea Sad
PostPosted: Sat Oct 20, 2018 10:46 am    Post subject: Reply with quote
What's the difference ?
Satnav:
Car Average MPG :
Warthen
PostPosted: Mon Dec 03, 2018 12:14 pm    Post subject: Reply with quote
spikem wrote:
If you have mastered compound bows and the UK / ROI version of a Drive assist series that only has voice control , will this change to voice command if you update the map to a full Europe version.
It shouldn't matter if you upgrade it or not, right? It should still preserve its functionality. But I don't have it so I'm just guessing essentially.
b33jay
PostPosted: Mon Dec 03, 2018 5:44 pm    Post subject: Reply with quote
Not sure what the Op is asking but does a device sold as UK & Ireland have sufficient memory to be updated to a full (or even part) Europe map base?
The 2589 loses some commands if the original all Europe map is changed to a smaller map base to overcome the lack of memory. Commands to set up a route are no longer available and are restricted to history, favourites and Four Square only
PostPosted: Mon Dec 03, 2018 6:37 pm    Post subject: Reply with quote
[quote="b33jay"]Not sure what the Op is asking but does a device sold as UK & Ireland have sufficient memory to be updated to a full (or even part) Europe map base?
[/quotes]
Maybe not on board but it certainly can be by using a SD card. I upgraded my 2508 in exactly that way.
22.052 (08 May 24)
