Pocket GPS World :: View topic - Montana 600 System Reinstall
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
JoeGriffin
PostPosted: Fri Dec 30, 2016 7:59 pm    Post subject: Montana 600 System Reinstall Reply with quote
Is it possible to reinstall the operating system on the Montana?
I've got a problem, which a reset (hold top left corner while restarting) has failed to cure. The device works OK until I connect it to the PC (to transfer data). When I do the Windows "Safe Remove..." thing, it tells me it's safe to remove the Montana, but when I unplug it, it hangs. It stays showing the USB connection symbol and the power key doesn't work. The only way out that I've found is to briefly remove the battery.
I wonder if my last update (to 7.1) has screwed up and whether there's a way to force it to reinstall the system.
... Joe
Garmin Montana 600
Garmin DriveSmart 51LMT-D
Garmin Nuvi 2599LMT-D
PostPosted: Fri Dec 30, 2016 10:11 pm    Post subject: Reply with quote
It's a known issue with 7.10 I'm afraid. I suggest you live with it until there is a software update, or revert to an earlier version if you kept a copy of the previous gupdate.gcd file?
JoeGriffin
PostPosted: Sun Jan 01, 2017 4:37 pm    Post subject: Reply with quote
A pain, but I can live with it.
Best wishes for 2017.
... Joe
Garmin Montana 600
JoeGriffin
PostPosted: Sun Mar 05, 2017 9:51 pm    Post subject: Reply with quote
Version 7.20 now fixes it. 😊
... Joe
Garmin Montana 600
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.052 (08 May 24)
