Pocket GPS World :: View topic - What would you like to see implemented in the Memory-Map
Goto page Previous  1, 2, 3, 4
PostPosted: Fri Feb 16, 2007 9:37 am    Post subject: Reply with quote
You can change the track colour on the PDA, tap and hold the track, from the pop-up list select "Properties" colour, select the colour you want and hit OK, I find this useful if out walking mutiple trails, makes it easy to split up where you have been.
I think it will be some time before you see 3D with elevation on a PDA the units simply don't have the processing power to handle this - Mike
chenko
PostPosted: Thu Oct 09, 2008 9:18 am    Post subject: Reply with quote
Someone else (MikeB) has already mentioned this, but I second having multiple graphs on one view, so we can combine elevation vs speed etc (and more). Maybe the same with separate tracks to compare speed and such.
Also with MM supporting Garmin units etc, and they have already included heart rate data, would be nice to see them include cadence. Or make it a bit more open so its easier support custom fields (gpx extensions) so they don't need to code every individual item that comes along.
Oh, and more simply to start with, outputting HR in the custom GPX standard. Same for CAD if it imports it from the units, im not sure how it imports the stuff and if CAD is even held in the MMO file somewhere.
In the properties of a track. Having the time as HH:MM:SS would be nice rather than just HH:MM
Page 4 of 4
22.052 (08 May 24)
