Pocket GPS World :: View topic - Routing printing
Routing printing
jellied
PostPosted: Mon May 09, 2005 3:06 pm    Post subject: Routing printing Reply with quote
Been printing out various maps and routes and two questions:
1. Can the thin blue line marking the route you have plotted be altered to something more obvious (ideally like tracklogs yellow line that is wide and see-through).
2. Is anyone aware of the commercial issues surrounding printing maps from Memory Map - could print a few dozen and then sell them for a £1 a throw?
Mortiki_UK
PostPosted: Tue Nov 15, 2005 3:09 pm    Post subject: Reply with quote
jellied,
In the MM V5 Software you can customise the Line Properties, including changing color, style, thickness, and opacity.
No, this is against both the MM EULA and the OS Terms and Conditions, please see http://www.memory-map.co.uk/terms_and_conditions.htm#1 for details
Mortiki_UK[/url]
jellied
PostPosted: Tue Nov 15, 2005 3:12 pm    Post subject: Reply with quote
Thanks - it's shame they waited until version 5 to allow you to change the line details.
PostPosted: Tue Nov 15, 2005 8:48 pm    Post subject: Reply with quote
You can do this in vs4, creat your track then right click it and from the popup box select properties, then use the colour box to change it to whatever you want - Mike
jellied
PostPosted: Tue Nov 15, 2005 8:56 pm    Post subject: Reply with quote
I think it was more the thickness than the colour I wanted to change. The colour is fine, but it's just to fine to see sometimes.
The Tracklogs product prints a pale yellow thick line by default that looks just like a highlighter pen.
Mortiki_UK
PostPosted: Wed Nov 16, 2005 11:39 am    Post subject: Reply with quote
mikealder,
Yes you are correct, you can change the color of the line within the MM 2004 Software, however that is far as the customisation goes for the software.
The MM V5 Software allows you to change Color, Thickness, Style, and Opacity of the lines.
Mortiki_UK
