Pocket GPS World :: View topic - Garmin 12 - desperate for help
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
Roger
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Garmin 12 - desperate for help Reply with quote
I have a Garmin 12 connected to a Loox running TT2. It locks up fine, but there is an offset to the position where the TT2 thinks it is, to the actual position, approximately 30 metres. This means you turn down a sidestreet after you have made the turn onto the main road, because of the difference in position.
The TT software manual states that (QUOTE)
Correct GPS position... Permanently adjusts the GPS position with an offset so that the location on the map matches the current GPS position. Only use this option with GPS receivers that introduce a constant deviation.
Question: how the B****y H**l do you get this option up on TT2? Have tried everything I can think of.
Am also posting this on the TT2 topic, as I am getting desperate now as I am leaving the country on Wednesday.
Any help gratefully received.
Cheers,
Roger.
R D
Are you using Map Datum WGS84 ?
Roger
Dave I think you may have made me into a happy little bunny.
Never found it last time looking through the Garman!
Roger
R D
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.053 (15 May 24)
