Pocket GPS World :: View topic - Problems uploading update 4.00
dandywarhol
PostPosted: Sun Aug 13, 2006 11:43 pm    Post subject: Problems uploading update 4.00 Reply with quote
I'm having problems updating to 4.00 (downloaded from R Elsinger's site) - keeps telling me to ensure:
"Interface option set to Garmin or Host"
Same problem downloading from Quest to PC. The PC has Mapsource V.6 loaded and the Quest has V7. I cannot load V7 as a disk has cracked Sad
PC/Quest doesn't seem to communiicate via the USB port
any ideas/help?
Garmin Quest|Ram Mount|Yamaha TDM900
At the cutting edge of technophobia
elsinga
PostPosted: Mon Aug 14, 2006 8:56 am    Post subject: Reply with quote
Might just be an USB driver issue... Any HP printers connected? Might also be the USB part on the Quest acting up, in that case you need www.elsinga.net/quest-first-aid
Robert Elsinga =8- )
GPS V FAQ Quest FAQ
Home @ N 52"55.812', E 05"51.509'
dandywarhol
PostPosted: Mon Aug 14, 2006 2:58 pm    Post subject: Reply with quote
thanks (again) Robert, but what does "Interface option set to Garmin or Host" mean and how do I set it?
Is it the case that you cannot work in version 6 on the PC if you have V7 on the Quest?
