Pocket GPS World :: View topic - Mamaory Map won't work with Active Sync 3.7.1
PeterB
PostPosted: Mon Oct 20, 2003 2:04 pm    Post subject: Mamaory Map won't work with Active Sync 3.7.1 Reply with quote
Sad Sad
This am I tried to run Memory Map on my PC and did not get past the intro. page.
Tried lots of ideas including re-loading prog. etc.
Memory Map have just become aware that The new version of Active Sync , V 3.7.1, STOPS MM working on a PC.
They are working on a solution but it will take a couple of weeks!!
Current recommendation is to re-load a lesser version of Active Sync (3.7)
BUT try as I might with V3.5 and 3.7 I still end up with an indicated 3.7.1 and NO MM.
When Active Sync is removed then MM will work OK BUT whenever I try to load any version of Active sync my computer (OS ME) reverts to 3.7.1.
Any ideas????? Question
For ALL MM users DO NOT install Active Sync 3.7.1!!!!!!!!!!!
PostPosted: Mon Oct 20, 2003 8:01 pm    Post subject: Reply with quote
You need to uninstall ActiveSync 3.7.1, restart and reinstall ActiveSync 3.5
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=4000
