Eugene7 Lifetime Member
Posted: Fri Oct 07, 2011 4:07 pm Post subject: SpeedCams need updating for Sygic |
The .bmp images with the Sygic Speedcam downloads for Sygic need to be changed - Sygic uses square 100x100 images, either 8 bit or 32 bit bmp format.
Also, the UK Consolidated SpeedCam data loads ok into Sygic (after using the Sygic POI Converter), but the Europe SpeedCam data causes a load failure error in Sygic.
Any ideas why this error is happening?
Cheers. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Fri Oct 07, 2011 4:14 pm Post subject: |
the current images work fine for me. where do you get the 100x100 size from? that seems pretty large!
does the upi / rupi convertor give any error with the europe cams? any line number or anything like that?
MaFt |
Posted: Fri Oct 07, 2011 10:07 pm Post subject: |
The POI size of 100x100 is from the Sygic website.
There are no poi conversion errors with conversion software - the problem is when trying to install them...
Guess this could mean a Sygic error? |
Posted: Sat Oct 08, 2011 11:46 am Post subject: |
The error on importing Europe Speed Cams seems to be that with Sygic you can only import POIs for maps you have active...
So, as I have UK, France and Italy only I can't use the Pocket GPS Speed Cams for Europe, as they need maps within Europe I don't have!
We need the Europe Speed Cam data base to be split into separate countries. |
Posted: Mon Oct 10, 2011 5:12 pm Post subject: |
Can we get the EUR SpeedCam data broken down into Countries for Sygic??? |
Posted: Mon Oct 10, 2011 11:49 pm Post subject: |
At the moment, no... Sorry...
MaFt |
peterc10 Frequent Visitor
Joined: Aug 21, 2005 Posts: 1761 Location: Kent, England
Posted: Tue Oct 11, 2011 9:50 pm Post subject: |
MaFt wrote: | At the moment, no... Sorry...
MaFt |
Not even if we are really nice and say pretty please? _________________ Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Thu Oct 13, 2011 7:19 pm Post subject: |
Eugene7 wrote: | The POI size of 100x100 is from the Sygic website.
What it says on Sygic:
Quote: | The icon (.bmp file) should be in square format e.g. 100x100px. If the icon is too big or too small, it will be adjusted automatically by the app.
The icon should be either 8 bit or 32 bit bmp format |
Posted: Thu Oct 13, 2011 7:55 pm Post subject: |
The bit about the software adjusting it automatically is wrong, to a certain extent.
These icons are used in two ways by Sygic. First they show on the map in the position of the camera, but that is always small and that does not change with file size. The second way is that they also appear in a separate pop up box with a count down of the number of yards away they are. It is this part that does not work automatically - the size of the icons depends upon the size of the file and is too small for what I am using (some 44 x44 ones I found).
I think the pop up box is a very good feature if only I could get the icon to fill its box. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Sat Oct 22, 2011 4:38 pm Post subject: |
MaFt, what are the countries covered in the Euro SpeedCam Database?
I will need to get all the countries for now to enable the database to install.
Also, I have found 88 x 88 px icons to be the best seize overall for Sygic. |
Posted: Sat Oct 22, 2011 8:02 pm Post subject: |
Eugene7 wrote: | MaFt, what are the countries covered in the Euro SpeedCam Database?
You can find the info by clicking on "download speed cameras" then clicking on "Click here to see a full breakdown of both UK and International cameras in the current database". _________________ Peter
HTC Sensation
Copilot for USA
wrinklyninja Occasional Visitor
Posted: Wed Jul 25, 2012 3:04 pm Post subject: Sygic/Aura Europe |
I agree with previous post. Sygic will not accept a Europe wide database. Only individual countries. UK works a treat but can't get any cameras installed for Spain. I guess that's a pain in Spain (groan).
Might have to start saving for the TomTom Android app. (if and when it ever arrives) unless the wizards here can sort a fix. |
Posted: Wed Jul 25, 2012 4:53 pm Post subject: |
Hmm - will have to look into that. Not sure there'll be any easy way to do it :/
MaFt |
