Pocket GPS World :: View topic - CheckPoint 5.0.0 is available for TTN5
davehardy20
PostPosted: Mon Aug 01, 2005 4:24 pm    Post subject: CheckPoint 5.0.0 is available for TTN5 Reply with quote
Hi Everyone,
I've just downloaded Checkpoint 5.0.0 for TTN 5, but have not had much success with it yet, hope someone else can get it to work.
Please can anyone help me with this, because Checkpoint is the best there is
davehardy20
PostPosted: Mon Aug 01, 2005 5:22 pm    Post subject: Reply with quote
Checkpoint 5 seems to lock up Tom Tom 5 when installed
jandevries12
PostPosted: Mon Aug 01, 2005 5:29 pm    Post subject: Reply with quote
Dave, what kind of PDA do you use? And what kind of operating system does it run?
On my Cassiopeia (PPC2002) CheckPOInt 5 runs smooth as a baby!
davehardy20
PostPosted: Mon Aug 01, 2005 5:32 pm    Post subject: Reply with quote
My PDA is an ASUS A620 running PPC 2003 ROM version V3.03.31 WWE, ROM date 2004/02/12
Hoppy
PostPosted: Mon Aug 01, 2005 7:25 pm    Post subject: Reply with quote
I have just installed it on my iPAQ 2210 and it's all working fine for me. It's graet to have it back :P
Pocketgps
PostPosted: Mon Aug 01, 2005 7:41 pm    Post subject: Re: CheckPoint 5.0.0 is available for TTN5 Reply with quote
davehardy20 wrote:
Hi Everyone,
The Author now says
At this moment CheckPOInt 5 can not be downloaded.
Too many people report stability problems with this new version.
It will be back in a few days, once the problem is solved.
Hoppy
PostPosted: Mon Aug 01, 2005 9:04 pm    Post subject: Reply with quote
I've just clicked on the download link again and it downloaded, I will say though although it seems to work fine once, but when you close TT it does not close down CheckPOint properly and unless you do a soft reset you can't start TT again. Also somebody has been messing up the databases again for example the SPECS Cameras just outside Newark on the A46 I deleted all the duff ones properly then parked next to the cameras and added them properly then uploaded them to the site for a few weeks they were fine but, I've just looked at them today after syncing again and there are several sets of SPECS, a few 40's and a couple of unknowns, all in slightly different places, I'm starting to lose a bit of faith in the way their database is updated. Back to using the GPSWorld Camera's for me it's ashame really I prefer the time from camera instead of the distance. Crying or Very sad
davehardy20
PostPosted: Tue Aug 02, 2005 5:22 pm    Post subject: Reply with quote
Hello Everyone,
A new version of CheckPoint 5 is on the website (v5.0.1), this seems to work on my ASUS at the moment, will keep you posted.
Asus A620, Holux GM 210 TTN v5.21 v6 Maps
CheckPoint 5
ttrevor
PostPosted: Tue Aug 02, 2005 6:41 pm    Post subject: Reply with quote
Just downloaded Checkpoint 5.01 and it freezes TT5 ,had to hard reset pda ,thank goodness for sprite backup,must still be a bug in Checkpoint,anyone had any problems.
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
Hoppy
PostPosted: Tue Aug 02, 2005 7:31 pm    Post subject: Reply with quote
Just downloaded 5.01 seem to work OK, a lot better than the problems I had with 5.00, still not sure how good the database is though.
CalumLawson
PostPosted: Tue Aug 02, 2005 10:08 pm    Post subject: Reply with quote
I likewise have had a problem. Checkpoint installs and I can start it up and access all the option, except when I select "Navigate" TT5 launches but stays on the Navigate screen with a black square in the top right corner where "Welcome to TomTom Navigator" appears on a normal startup.
Likewise if I launch TT5 directly it hangs at the same point (without Checkpoint started.
I did several soft resest in between attempts with no success, the only solution was a hard reset and restore from Sprite backup.
iPAQ 2210 with Rom 1.10
davehardy20
PostPosted: Wed Aug 03, 2005 10:24 am    Post subject: Reply with quote
Hi Again,
After installing CheckPoint 5.0.1 I was able to setup checkpoint and I even configured a few warnings but when I ran TT the PDA locked up and needed a soft reset to un lock it. It seems that there are still a few bugs to be ironed out, but the product looks very good up to now.
Keep up the good work OABsoftware.
CheckPoint 5
davehardy20
PostPosted: Wed Aug 03, 2005 3:51 pm    Post subject: Reply with quote
Hello
Success this time, I've upgraded TTN5 to version 5.1 and reinstalled CheckPoint 5 and everything seems OK now. Will update if required.
CheckPoint 5
Hoppy
PostPosted: Wed Aug 03, 2005 8:24 pm    Post subject: Reply with quote
Now I have played with 5.01 and worked out that I can set the warnings to the pocketgpsworld camera POI's and turn off the visual display to stop the flickering, it's great to have a distance warning from a POI again. it is also great to be able to start CheckPOint from inside TT with the addition of the menu item. All in all I think it is very good it would be slightly better if the visuals could be sorted but I don't need to see anything really when I've had a 30 second a 10 second and a speed limit warning. :D :D :D :D :D
Mearns
PostPosted: Fri Aug 05, 2005 1:52 pm    Post subject: Reply with quote
Just to add my experiences:
Before installing CheckPOInt I had no problems with my 2210 running TomTom 5.00.
CheckPOInt 5.0.1 locked up my 2210 running TomTom 5.0.
Upgraded TomTom 5.0 to 5.1 - CheckPOInt 5.0.1 runs fine except for the known issue of flickering warnings.
Took me ages to find this one out - if you are checking the volume of .wav files in CheckPOInt, make sure you also have TTN5 running as well - I wasted a couple of hours trying to increase the volume of my .wav files when there was no need. Embarassed
Tony
nuvi 2460LT plus Brodit mount
