Pocket GPS World :: View topic - Warning on Speed Limits
Rayg
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Warning on Speed Limits Reply with quote
Hi All
I have a small problem on my newly loaded GPSassist, I have loaded a new WAV file for warnings But I sem to get a German waring when going over my pre selected speed limit. I can play my new warning on the GPSassist settings screen OK but it just doesnt play when triggred by the selected speed setting.
Thnx for your help.
Ray G
The speed warning is a hard coded WAV file, you'll find this in the GPSAssist directory. If you rename this to a .old and put your new WAV in and rename it to the original name, restart GPSAssist and TomTom Navigator and you should get your new warning.
This warning cannot be customised in the interface for exceeding the manually set speed limit, only the speed camera warning can, if you follow the above, you should be able to manually overwrite with your wav file, but beware if you re-install GPSAssist, copy your WAV out first because it will overwrite it again.
