Pocket GPS World :: View topic - Change TT5 menu possible
Goto page 1, 2, 3 ... 11, 12, 13  Next
newmikey
PostPosted: Wed Jun 15, 2005 1:27 pm    Post subject: Change TT5 menu possible Reply with quote
Found on Dutch and German forums (translation mine, idea and execution not)
http://www.pocketpc-club.nl/forum/showthread.php?t=53822&page=1&pp=15
and
http://www.pocketnavigation.de/board/thread.php?threadid=69041&threadview=0&hilight=&hilightuser=0&page=1
It is possible to design your own menu in TTN5. That way you can adjust the menu to suit your preferences so that you can f.i. shut down TT from within the first menu screen.
You have to follow this procedure:
Make a textfile using notepad.exe including the rearranged menuitems and save it as TomTom.mnu in the directory TomTom/SDKRegistry
The menuitems can be found in a textfile.
Links to the textfiles:
http://www.pocketnavigation.de/board/attachment.php?attachmentid=16723
and
http://www.pocketnavigation.de/board/attachment.php?attachmentid=16724
example:
dunos
PostPosted: Wed Jun 15, 2005 1:38 pm    Post subject: Reply with quote
I am very impressed, that really works!
Thank you very very much!
julianbarker
PostPosted: Wed Jun 15, 2005 2:50 pm    Post subject: Reply with quote
Very nice! After an hour playing around with that I now have some very good menus!
jweaver
PostPosted: Wed Jun 15, 2005 3:42 pm    Post subject: Reply with quote
I was all excited by this, but as a Palm user, it seems that the "SDKRegistry" directory does not exist.
We get the 'SdkFileCalls' directory, but not the other.
So, it looks like on the Palm, menus are done differently Sad
soweezy
PostPosted: Wed Jun 15, 2005 3:56 pm    Post subject: Reply with quote
no SDKRegistry folder on PPC either Confused
SW
Garmin Zumo 390LM
newmikey
PostPosted: Wed Jun 15, 2005 4:20 pm    Post subject: Reply with quote
No problem, just make a new folder under TomTom. Call it SDKRegistry and copy your TomTom.mnu file in there.
I did it exactly like that!
jweaver
PostPosted: Wed Jun 15, 2005 4:28 pm    Post subject: Reply with quote
Ahha.. I will give it a go.. Care to share your 'Menu' file with us? Smile
jweaver
PostPosted: Wed Jun 15, 2005 4:54 pm    Post subject: Reply with quote
Nope.. Doesn't seem to work on the Palm.
I have created the "SDKRegistry" directory under "TomTom".. I then copy/pasted the contents of the 2nd file (in the link above) into a file called "TomTom.mnu" in the SDKRegistry directory and then launched TomTom.
But the menus are still the same...
Jon
newmikey
PostPosted: Wed Jun 15, 2005 5:03 pm    Post subject: Reply with quote
Jon
I might have been more specific. The file is an example, in order to make a working menu out of it you have to delete the first two lines.
It starts off so:
Die Datei kann mit einem Editor blah blah etc
MENUBLOCK BLOCK_MAIN BTM_GPS_POSITION
MENUPAGE TASK_PAGE1 Custom menu 1
MENUITEM TASK_EXIT_APP Anwendung schließen
Delete the line that starts with "Die Datei " and the empty line following it.
It should work now!
newmikey
PostPosted: Wed Jun 15, 2005 5:06 pm    Post subject: Reply with quote
Jon
I might have been more specific. The file is an example, try using the first link. Don't worry, you can do anything wrong.
I'll post my file:
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Basisnavigatie|
MENUITEM|TASK_EXIT_APP|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_SWITCH_NIGHTVIEW|
MENUITEM|TASK_SET_MAP|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Uitgebreide navigatie|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_DELETE_ROUTE|
MENUITEM|TASK_PLAN_VIA|
MENUITEM|TASK_MENU_PLAN_ATOB|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Favorieten en POIs|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_MAINTAIN_FAVORITES|
MENUITEM|TASK_CONFIGURE_POI|
MENUITEM|TASK_MAINTAIN_POI|
MENUITEM|TASK_SWITCH_POI|
MENUITEM|TASK_PAGE4|
MENUPAGE|TASK_PAGE4|Systeeminstellingen|
MENUITEM|TASK_SET_VOICE|
MENUITEM|TASK_SHOW_GPS_STATUS|
MENUITEM|TASK_SET_BACKLIGHT|
MENUITEM|TASK_SET_COMPASS|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_PAGE5|
MENUPAGE|TASK_PAGE5|Kleuren, maten en taal|
MENUITEM|TASK_SET_DAY_COLOR_SCHEME|
MENUITEM|TASK_SET_NIGHT_COLOR_SCHEME|
MENUITEM|TASK_SET_DIST_UNITS|
MENUITEM|TASK_SET_LANGUAGE|
MENUITEM|TASK_ROTATE_DISPLAY|
MENUITEM|TASK_PAGE6|
MENUPAGE|TASK_PAGE6|Diversen|
MENUITEM|TASK_SWITCH_2D3D|
MENUITEM|TASK_AVOID_ROUTE_LINE|
MENUITEM|TASK_CHANGE_HOME_LOCATION|
MENUITEM|TASK_SET_KEYBOARD_SIZE|
MENUITEM|TASK_SET_PLANTYPE|
MENUITEM|TASK_PAGE7|
MENUPAGE|TASK_PAGE7|Voorkeuren|
MENUITEM|TASK_SET_STATUS|
MENUITEM|TASK_SET_NAME_DISPLAY|
MENUITEM|TASK_SET_TOLL|
MENUITEM|TASK_SET_PROMPT|
MENUITEM|TASK_SET_VOLUME|
MENUITEM|TASK_PAGE1|
newmikey
PostPosted: Wed Jun 15, 2005 5:08 pm    Post subject: Reply with quote
Jon
It starts off so:
It should work now!
Is it possible to delete this answer? The cond post following jweavers question is the correct answer. I must have been suffering acute caffeine depletion symptoms.
jweaver
PostPosted: Wed Jun 15, 2005 5:30 pm    Post subject: Reply with quote
Nope.. Still no good!
Even if I copy/past your file into my TomTom.mnu file, my menus don't change.
I really don't think that this is going to work on the Palm Sad
Its a shame.. I only want to move that wretched 'TomTom Traffic' button off of the front screen and replace it with something more useful!
Jon
jweaver
PostPosted: Wed Jun 15, 2005 5:34 pm    Post subject: Reply with quote
newmikey,
I have read your last posts again and understand what you are saying.. I had already reaslised this when I did my first test.
I already removed the 'text' at the top of the page, and simply pasted in the MENU parts which began with:
"MENUBLOCK BLOCK_MAIN BTM_GPS_POSITION"
Jon
newmikey
PostPosted: Wed Jun 15, 2005 6:06 pm    Post subject: Reply with quote
jweaver wrote:
newmikey,
Jon
I know you did, or I expected such. The file I am looking at in your last post (pun unintended) is just the example file. Discard it, copy the example in my last post (again...) into an empty file and name it TomTom.mnu. It MUST work! It worked for others on Palm, so why not for you? Did you ever treat your Palm unfair?
Don't want to poke your eyes out, but have a look at my menus:
The rest of them, 7 in total are on my pbase gallery at http://www.pbase.com/newmikey/crops
AndyCr15
PostPosted: Wed Jun 15, 2005 6:11 pm    Post subject: Reply with quote
Should there already be a tomtom.mnu file anywhere? Like a default one or something? Or are we creating the sdk folder and then the menu file from scratch as it were?
I would prefer to have the default one, and then cut and paste a few commands as needed Smile
TomTom 6 - SPV M5000 and WM6
Garmin Zumo 500 on Honda TransAlp
www.lanarchy.co.uk for LAN gaming near London
ICQ Number
Page 1 of 13
23.054 (28 May 25)
