zoomzoom Occasional Visitor
Posted: Mon Jan 31, 2005 4:43 pm Post subject: January 2005 database |
Just downloaded the latest update - WOW!! - Cameras now grouped in speed limit zones with associated icon and audio warnings. Time to go for a run to see how it all works!! |
buckman Regular Visitor
Posted: Mon Jan 31, 2005 5:58 pm Post subject: |
where is this? is this the new Camera Only update or Software update for Go?
where is this?  |
Joined: 30/12/2002 17:36:20 Posts: 4919 Location: Oxfordshire, England, UK
Posted: Mon Jan 31, 2005 6:08 pm Post subject: |
Hi Buckman,
It’s the latest version of the PocketGPSWorld camera database, which you can see here.
It looks like Richard (Oldie) has done a lot of work in splitting/grouping the cameras into known speed limits. Well done Richard!
Garmin Camper 770 LMT-D |
duckie008 Regular Visitor
Posted: Mon Jan 31, 2005 7:03 pm Post subject: |
Just downloaded the updated database. There a several folders each containing several files in them. Which files do i need to copy on to the SD card? And do i delete the previous files first? |
gingernut777 Frequent Visitor
Joined: Nov 03, 2004 Posts: 251 Location: Earth where else
Posted: Mon Jan 31, 2005 7:20 pm Post subject: |
Also where do we put the Wav files 20, 30,40 mph files, and how do we select them. _________________ Using an A to Z
Sextant & Compass |
Big_Wool Occasional Visitor
Posted: Mon Jan 31, 2005 8:15 pm Post subject: |
gingernut777 wrote: | Also where do we put the Wav files 20, 30,40 mph files, and how do we select them. |
I too would appreciate an answer to this question! |
SgtRock Occasional Visitor
Posted: Mon Jan 31, 2005 10:33 pm Post subject: |
Great stuff
One slight issue the filenames are getting a bit long.
I've thought up a nice way not to split the files up and have suggested the following to TomTom :-
It would be nice if when warn near POI's is set you could display some text when the icon flashed up. i.e print the text to the right of the @ to the right of the flashing icon.
-4.87511 , 50.41278 , "GATSO:1973@60"
-2.13296 , 51.67149 , "Andy Smith@22"
Great for when getting near a speed camera or when near a house number.
XXXXX 22
XXXXX
XXXXX
XXXXX
100 |
Posted: Mon Jan 31, 2005 10:55 pm Post subject: |
Hi gingernut777,
Can TomTom GO use custom sound files? I would imagine that the WAV files are for applications like CheckPOInt, GPSAssist, and POIWarner, etc.
As the PocketGPSWorld camera database is for many different SatNav packages I’ve moved this thread to a more appropriate area of the forum.
Dave Frequent Visitor
Posted: Mon Jan 31, 2005 10:58 pm Post subject: |
WAV files can't be used on TTGO, only apps that support WAV files. |
Jo Regular Visitor
Posted: Mon Jan 31, 2005 11:36 pm Post subject: |
Where can i find a step by step guide on how to install this with tomtom go, what dir do i put it in and what do i need to get it to work, what size card. |
Podie Occasional Visitor
Posted: Tue Feb 01, 2005 9:22 am Post subject: |
Looking at the ZIP file… it seems as if TTG users should delete all the *.wav and *.txt files.
However, I'm not sure if there is anything else we need to remove, or as before do we just copy the OV2 and BMP files to the SD Card into the Great Britain Directory and enable them in the POI screen….. |
Posted: Tue Feb 01, 2005 9:59 am Post subject: |
Yes, could we have a step by step way of installing this please?
And do we delete the other Speed camera databases so our GO's are clear before we input this one??
(ive only just installed the Dec update so do i delete it or leave??)
Zoober Occasional Visitor
Joined: Jan 22, 2005 Posts: 2 Location: Harrow London
Posted: Tue Feb 01, 2005 11:31 am Post subject: |
If you check the databases in POIEdit you'll see that the new gatso and mobile speed defined databases are the same as the standard databases. So if you install both the original gasto and mobile ov2 files and the new speed zoned versions then you will have duplicated all the gatso and mobile cameras. Therefore use one version or the other, but not both.
I just copied all the bmp and ov2 files from the speed zoned directory into the map directory on my sd card.
I ignored the two entries pocketgps_uk_gatso.ov2 and pocketgps_uk_mobile.ov2 (as I am using the speed zoned version)
The redlight, temp and specs cameras which aren't speed related were copied across as normal
The sound files went into the Checkpoint program directory.
Then I activated them in Checkpoint and added the sound files I liked.
Then I selected them in Tom Tom and that was that
I'm pretty sure I'm correct about not using both the original and speed zoned version but maybe wait for someone brighter than me to confirm? |
Oldie Pocket GPS Moderator
Joined: 22/11/2002 13:33:48 Posts: 992 Location: Surrey, UK
Posted: Tue Feb 01, 2005 12:59 pm Post subject: |
If you look in the readme.txt file that is in the pocketgps_uk_sc.zip file it does state, in the paragraph that refers to the new speed related files, that
"These files can be used instead of the baseline distribution"
By baseline I mean those files that you have been used to using. So the choice is yours.
Richard _________________ Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405 |
Posted: Tue Feb 01, 2005 1:24 pm Post subject: |
Oldie wrote: | If you look in the readme.txt file that is in the pocketgps_uk_sc.zip file it does state, in the paragraph that refers to the new speed related files, that
Richard |
Sorry, not had time to browse through the files properly, but have now scanned the readme file.
I appreciate that PocketGPS provide this database free of charge (and I for one am very grateful!) but there are some people who simply are not as technical or as familiar with PC's as others, and I get the impression there are some frustrated newbies about.
TTG also works in a slightly different was to TT3, so perhaps a list of files or basic, step-by-step instructions would help people...? |
