jim1218 Occasional Visitor
Posted: Thu Feb 24, 2005 10:38 pm Post subject: screen protector |
just bought Tomtom Go from globalpositioning systems with their
"Writeshield AG 1-pak" It was a good fit on the GO screen but stickyside easily attracts dust etc as you fit it. After using the GO a bit it seemed to completely lock up, with screen taps not possible. I discovered luckily, as you have, that the protector had got itself beneath the screen frame mainly due to my efforts at sliding the maps around. The gap must be just a bit smaller than the protector thickness and this creates a constant "screen key press"
Otherwise as a beginner, gob smacked at the terrific overall performance of the GO. Thanks to you all for this wonderfull site |
JohnBoy59 Regular Visitor
Posted: Thu Mar 03, 2005 11:29 am Post subject: |
I have just started using a screen protector from the Brando Workshop. I thought it was expensive at first (about £6) but I can thoroughly recomment it. Its easy to apply completely cuts out reflections and makes the TTG much more useable even in direct sun light. You can even remove the sheet and wash it!! The TTG's main drawback is its screen is hopeless in sunlight - this product eliminates the problems - why TomTom dont modify their production to incorporate this or something similar is beyond me.
http://shop.brando.com.hk/screenprotector.php _________________ Life's a bitch... then I met Jane... |
CHEDS Regular Visitor
Posted: Thu Mar 03, 2005 3:22 pm Post subject: |
Do they make a screen protector for the Go or did you order a different one ? |
Posted: Thu Mar 03, 2005 3:49 pm Post subject: |
They make one specifically for the Go _________________ Life's a bitch... then I met Jane... |
Posted: Fri Mar 18, 2005 2:38 pm Post subject: |
Ive just recieved my screen protector from Brando Workshop but eveytime I put it on I keep getting bubbles in it, is there an easier way to get rid of the bubbles or am I doing something wrong ? |
Posted: Fri Mar 18, 2005 4:35 pm Post subject: |
I found that if you wash it , shake it almost dry then put it on any remaining moisture reduces the cling and makes it easy to position and squeeze the air bubbles out to the edges. _________________ Life's a bitch... then I met Jane... |
Posted: Fri Mar 18, 2005 5:00 pm Post subject: |
Just tryed that Johnboy still can't get some of the bubbles out |
Posted: Fri Mar 18, 2005 5:34 pm Post subject: |
If its applied slightly wet then the bubbles go after a day or so as it dries out. Not had any problems with mine _________________ Life's a bitch... then I met Jane... |
Posted: Fri Mar 18, 2005 7:10 pm Post subject: |
I will see what its like when it drys thanks for the quick reply |
Fibre Frequent Visitor
Joined: Nov 17, 2004 Posts: 368 Location: Kettering, Northants, England
Posted: Sat Mar 19, 2005 1:18 am Post subject: |
had my TOMTOMGO since October and haven't had the need for a screen anti glare protector - I just left the thin bit of plastic on the screen that came with TOM -- :D
However the SUN 8) is now shining and this makes the screen particularly difficult to see. So today
- following the instructions to the letter
- even washing my hands with soap
- cleaned the screen with the brush
- then the wipe and then polished it off so as to "see your reflection"
- I fitted the little bit of plastic with a small gap around the edge
- no air bubbles or any thing.... GREAT...
took it out side to try and THE SUN HAS GONE IN !!! _________________ Happy to meet -- Sorry to part -- Happy to meet again |
Posted: Mon Apr 11, 2005 12:28 pm Post subject: |
Fibre wrote: |
took it out side to try and THE SUN HAS GONE IN !!! |
Sun was out on a trip the other day - just before it snowed...
I feel that the anti glare protector isn't that brilliant.. It seems to reflect more of what is in the vehicle -- for example if you are wearing a light top or shirt that seems to be reflected back and the definition of the screen colours is lost..
Not that impressed... _________________ Happy to meet -- Sorry to part -- Happy to meet again |
nushieldguy Occasional Visitor
Posted: Mon Jun 20, 2005 7:07 pm Post subject: NuShield is clearer and easier to install screen protector |
NuShield screen protectors do not use adhesives to stick to the screen so there are no Air bubble problems!!!
At this point there are no screen protectors that work in direct sunlight. Anyone who says theirs does is lying.
NuShield films are easy to install and each film will last about one year of normal use. That is a claim that most adhesive types cannot make.
NuShield films cost only $11.99 for 3, a bargain compared to others.
You can order NuShield films at: http://www.nushield.com/buy.htm
Just use the Manufacturer pulldown menu to select TomTom and then select Go under model.
If you have any questions I will be happy to answer them if you post it here. |
JoeJordan Occasional Visitor
Joined: Jun 07, 2005 Posts: 19 Location: Sunny Staffordshire
Posted: Wed Jun 22, 2005 7:08 pm Post subject: |
Just received 'digital camera screen protector kit' from www.7dayshop.com for £1.99. Comes with three 10cm X 8cm screen protectors, cleaning wipes and a squeegee card to help you apply.
Cut one to size and hey presto looks fine.
Maybe VERY slightly more reflective but does the job.
Problem is the £3.95 postage. But you could combine it with an SD card or whatever. |
lostgerry Occasional Visitor
Posted: Wed Jul 06, 2005 6:54 pm Post subject: Re: TomTom GO screen protectors review |
gingernut777 wrote: | MikeB wrote: | .
I use "Acetate Film" bought at any Arts & Craft shops for a couple of quid.
The type you require is Economy Clear Acetate 20 in. x15 in. sheet .003" thick. Cut it to size, you get about 15 to 20 pieces. They do the job perfectly. |
I am fed up trying to find this product Gingernut ! I must have the wrong sort of model shops in my area ?? none have heard of this ? can you give me a Phone number of a shop that will sell me a sheet of the anti reflective sort please m8 ? would be most greatfull :D |
