Pocket GPS World :: View topic - REVIEW COMMENTS: Leadtek 9532
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: REVIEW COMMENTS: Leadtek 9532 Reply with quote
We've completed the review of the Leadtek 9532. There really isn't much difference between the 9531 and 9532 apart from the 9532 supporting SiRF II.
The full review is available here
Please post any comments regarding the review here.
simontdc
Dave, we now have the 9532 in stock with 39xx cables, Dell Axim, Pocket Loox, Casio etc.
Webshop is at http://www.tdcltd.sageweb.co.uk/catalogue/default.htm (these prices include carriage to UK address, although is is added by the basket process it won't be added - so price is £109.99/£114.99). More details at http://www.tdc.co.uk/gps/gps_receivers_leadtek.htm#9532cable
Cheers,
Simon
G1NTX AFRIN LRPS
Martinh1
PostPosted: Sat Mar 12, 2005 9:08 am    Post subject: leadtek 9532 Reply with quote
Have recently purchased this item
being used with Ipaq 5450
Cant get a signal on the GPS
Have tried a combination of ports a protocol
I understand it should be com 1
it is used with Tom tom
I have taken tom tom off the machine and done a hard reset
Installed leadtek's own software, still no signal
Have a flashing green light on Gps unit
Any help would be appreciated
DavidW
PostPosted: Sat Mar 12, 2005 2:32 pm    Post subject: Reply with quote
It should work with "TomTom Navigator GPS" and "Serial cable on COM1:"
It sounds as if you've got power through the cigarette lighter plug, which is required for a wired GPS. You need to disable any drivers for plug in keyboards, as they sit on the serial port.
If those two things don't get you working, there's a couple of other possibilities that are reasonably likely. One is that the GPS isn't set to NMEA 4800bps - in which case you may need to try to 'find' it with the likes of Leadtek Navigator.
The other possibility is that you've got the wrong connecting lead. Some of the other Pocket PCs, such as the XDA, use the same 22 pin connector as modern iPAQs, but the serial port pins are connected differently.
Martinh1
PostPosted: Sat Mar 12, 2005 2:41 pm    Post subject: Reply with quote
I have been using Leadtek Navigator with no joy
I do not use any other devices with the Ipaq so I can only presume the lead is wrong, even though it charges the Ipaq and green light on GPS
Who Knows
I will let you know how it goes with a new lead
DavidW
PostPosted: Sat Mar 12, 2005 3:46 pm    Post subject: Reply with quote
If you've tried Leadtek Navigator, then it's worth trying all the different serial port speeds, and SiRF binary mode as well as NMEA. If none of those work, then it's probably a hardware issue - the most likely being that you've got the wrong connection lead.
Martinh1
PostPosted: Tue Apr 05, 2005 8:10 pm    Post subject: Reply with quote
Well got a new lead and it works a treat
Many thanks all
