rafael Occasional Visitor
Posted: Fri Feb 18, 2005 4:52 am Post subject: Problem with DEll Axim x3i+ |
I have seeen your latest compatibility list ( axim x3 ) in previous post.
Seems doesn't work with dell axim x3i+.
The gps info didsn't show me the the nmea sentences when I click start.
The available port com is COM7: MANF-0501-CARDID, that driver gave.
The Led light is Red blinking.
What should I do ?
Can you help me Sean ? , I'm really frustrating on it .
Rafael
axim x3i+ with SD 501 |
mellis Occasional Visitor
Posted: Wed Mar 02, 2005 6:32 pm Post subject: SD501 |
Before i really lose my rag with this thing can somebody tell me how to get it to work with my Ipaq 2210 and Tomtom 3. I can get the GPS working alright but it won't communicate with Tomtom, it just locks the whole thing.
The two boxes to select your GPS:
- the top one has some well known makes
- the bottom one has the port (the GPS shows up as SDGPS fine
- what goes in the top one? i have tried the suggestions on other forums but nothing works
Someone please help?
Mellis |
EasyD2 Regular Visitor
![](modules/Forums/images/avatars/1657901726438c327304bf8.gif)
Posted: Wed Mar 02, 2005 6:54 pm Post subject: |
Have you tried setting the GPS Receiver at
NMEA 0183v2 4800 _________________ www.easydevices.co.uk
Tel: 0871 7000 156
Globalsat UK Distributor |
Posted: Wed Mar 02, 2005 6:58 pm Post subject: |
I certainly have but it just sits there and does nothing. Also, interestingly it doesn't actually allow me to tick the box, rather it flashes once but won't actually let me check the box!
How quickly should it pick up the GPS? |
Posted: Wed Mar 02, 2005 7:09 pm Post subject: |
I have already installed the HP SDIO fix, without it i couldn't get the GPS to work at all. I have tried them all but it just seems that the GPS won't allow itself to be detected by Tomtom!!! ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Wed Mar 02, 2005 7:12 pm Post subject: |
mellis, this may be an obvious question, but have you tried doing soft reset and failing that a hard reset (if this is an option) _________________ www.easydevices.co.uk
Tel: 0871 7000 156
Posted: Wed Mar 02, 2005 7:26 pm Post subject: |
Joy!!!!!!!!!!11 :P :P :P :P :P
Right then, the soft or hard reset didnt work! What you have to do is "Stop the GPS" in the SD501 software and forget about that, i have even uninstalled it. Then select NMEA 4800 v2 and robert's your fathers brother!
Praise the lord.
Thanks for all your help D2, we got there in the end!! |
Kaka Occasional Visitor
Posted: Sat Mar 12, 2005 12:44 am Post subject: SD-501 (X-Trac) SDIO GPS in XDA II using TomTom Navigator |
I recently bought SD-501 (X-Trac) SDIO GPS receiver and I want to use it with O2 XDA II which has 64MB base memory/RAM and 128SDRAM. I want to buy TomTom Navigation software which takes more than 100MB space to store application SW plus UK maps on XDA II.
I have seen compatibility list where Mike mentioned that SD-501 (X-Trac) SDIO GPS receiver is compatible with XDA II. Now I have following two questions to Mike:
1. How you can install TomTom when SD slot is occupied by SD-501 (X-Trac) SDIO GPS with just 64MB base memory in XDA II instead of SDRAM which provides extra storage media of 128MB (or more if higher size SD RAM card is installed).
2. Which alternate software (like TomTom) you may have used to test the XDA II compatibility ?
Your earliest reply will highly be appreciated.
Many thanks. |
Posted: Sat Mar 12, 2005 12:56 am Post subject: SD-501 SDIO GPS receiver in XDA II using TomTom Navigator ?? |
I recently bought SD-501 (X-Trac) SDIO GPS receiver and I want to use it with O2 XDA II which has only 128SDRAM. I want to buy TomTom Navigation software which takes more than 100MB space to store application SW plus UK maps on XDA II.
I have seen compatibility list of Mike where he mentioned that SD-501 (X-Trac) SDIO GPS receiver is fully compatible with XDA II. Now I have following two questions to Mike:
1. How you can install TomTom when SD slot is occupied by SD-501 (X-Trac) SDIO GPS with just a base memory in XDA II in absence of SDRAM which provides an extra storage facility.
2. Which alternate software (like TomTom) Mike may have used to test the SD-501 (X-Trac) with XDA II ?
Many thanks |
Posted: Sat Mar 12, 2005 4:44 am Post subject: SD gps is already working with my axim x3i+ but ... |
Dear Sean,
Thx for your advice on previous post. It's already working with installin sgps 1 bit driver.
But the problem now is, that it doesn't work or compatible with ozi ce 3.952. already check the same port (com 6) but still "error" in communicating... the message is "err" on top right corner of ozi.
any solution for that ?
thx in advance
Rafael |
DavidW Pocket GPS Moderator
Posted: Sat Mar 12, 2005 2:15 pm Post subject: |
A GPS is compatible if it works with a particular device. However, on devices with only one memory slot, taking the only memory slot for GPS hardware probably makes street navigation software like TomTom Navigator 3 unusable.
You'd get a far more flexible setup using another type of GPS with your XDA II - but if you insist on using the SDIO GPS, you'll have to live with whatever maps fit into main memory.
David |
Mehanik Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_matrix_004.jpg)
Joined: Jun 09, 2004 Posts: 26 Location: Moscow, Russia
Pocket-Man Occasional Visitor
Posted: Tue Mar 29, 2005 7:12 pm Post subject: |
I have hp2210 (rom 1.10 and SDIO driver updated) and SD-501 (X-Trac) SDIO GPS receiver. It's not working together at all.
After hard reset I have only installed: hp SDIO driver update, SDGPS4bit.exe (SDIO-driver), and GPSInfo application. The most interesting thing is that new COM-port (MANF-0501-CARDID-F501-FUNC-1) has not appeared after SDGPS4bit.exe installation.
I think i now the problem: even after hard-reset almost all COM-port (COM-1, COM-2, COM-3, COM-4, COM-5, COM-6, COM-8 and COM-9) are preinstalled (visible throw ComKiller utility). Maybe SD-501 driver simply can't allocate free COM port... But COM-port-killing has had no effect.
Maybe my GPS device is broken... When i dock it into SD-slot LED remains blank (not lighting). Is it ok?
Please somebody with same combination (hp2210 + SD-501) reply to me. I want to try some trick: if you make Backup of your system configuration (by IPAQ backup utility) i can try to restore from your backup.
Sorry for my english. |
Posted: Wed Mar 30, 2005 1:47 pm Post subject: |
I have found the problem. I have totaly disassembled my hp2210 and have found that one contact leg in the SD slot is bended wrong. |
