Pocket GPS World :: View topic - upgrade 2002 not working
keld
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: upgrade 2002 not working Reply with quote
Hi all,
I'm a newbi, and just bought a used (i.e cannot go back to a store) Ipaq 3630 ppc, also I got the Compaq CD including the upgrade PPC 2002. I am running active synch 3.5 and when I try to update to pc2002 I get an error 105 re. com port. I'm using a USB cradle/connection, and everything is working fine. But no possible update.
When checking the system, it says 2 com ports available and one USB available.
Any help would be appreciated
Regards
Ipaq 3600 2.07
Does AS see the iPAQ i.e. can you sync with it? Also is the cradle plugged into a USB hub or direct to USB on the PC?
Friendly
I havent experienced the problems you are having, although have had others.
Try upgrading to ActiveSync 3.6, and also check that you are using the latest BIOS version.
Friendly
22.055 (29 May 24)
