Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Mon Aug 21, 2023 10:18 am Post subject: Integration time... Using STA to submit to PGPSW Database
As many of you know I have been working alongside Leo_A to add a number of features to STA that work specifically with the PGPSW Database (eg the 'EXITSPECS' points that disable average speed when you turn off a main road without END camera etc).
Leo has also very kindly created a basic API that we can use to help with submissions to the PGPSW database from PGPSW members. I am now starting to work on this integration and there's a small change you need to make in the app to allow the submissions to be linked to your account.
In Settings - Databases find the PGPSW database and tap it to show the 'Database properties' pop up. On there, please click the "Attach my login to feedback" option. Only PGPSW will see these usernames via a secret key in the API. The data available in the public API will remain anonymous.
The first step of the integration will be for 'seen again' reports for mobiles (and pMobiles) as well as remove requests for all other fixed cameras. Without ticking the box mentioned above will mean that if your remove request is first then we will not be able to link it to your account for the free 1 year subscription.
Further down the line, new camera additions will also be available through STA. At present this is possible but there is no way to link it to your PGPSW user account.
I will update this post when the feature is tested, working, and live.
Posted: Mon Aug 21, 2023 10:22 am Post subject:
For now, if you need to make a new submission then create it in STA and before submitting it take a screenshot so you have the coordinates. You can submit these manually on the website.
Some phones (Oppo, OnePlus etc) have an excellent feature where you can swipe the phone with 3 fingers to take a screenshot. The Pixel phones you can tap the 'square' button (or swipe upwards) to show all the currently open apps and tap the 'screenshot' button.
Otherwise the standard 'power + volume down' button press will take a screenshot although this isn't easy when your phone is in a mount.
Regardless of which method you use to log the coordinates of a new camera, make sure you are pulled over/parked and it is safe to carry out the task.
Posted: Mon Sep 11, 2023 5:28 pm Post subject:
OK - phase 1 is complete!
Certain submissions/requests from SpeedTrap Alert will now be used in the main PGPSW database.
So far these are:
- Removal Requests (Report problem: Not here)
- Mobile Seen Again reports (Report problem: Confirm)
- Other change requests (Report problem: Wrong limit / Bad location / Other)
Comments can be added and will be helpful, as always!
'Confirm' of non-mobiles are filtered out and ignored.
'Not here' requests for mobiles are ignored - unless comments are submitted.
Any other changes (Wrong limit, Bad location, Other) will be submitted as a change require and will need comments (otherwise they will be rejected when I process them).
IMPORTANT!
For any submissions (removals, change requests) to result in a free subscription you need to link STA to your PGPSW account and give permission to share your username.
In Settings - Databases find the PGPSW database and tap it to show the 'Database properties' pop up. On there, please click the "Attach my login to feedback" option. Only PGPSW will see these usernames via a secret key in the API. The data available in the public API will remain anonymous and will never show any userid's.
Today I'm going to rollout next version that submits new cameras with PGPSW usernames included (https://api.speedtrap-alert.cc/v1/pgpsw/realtime/?interval=P7D)
Posted: Mon Sep 11, 2023 9:59 pm Post subject:
Thanks Leo,
This can be a project for later in the week... Been a loooooong day coding today!
features[i].properties.type : speed camera type (1 - fixed, 2 - redlight, ... , 5 - mobile, .. etc);
features[i].properties.speed : 0 - unknown, otherwise speed from OSM;
features[i].properties.dir : movement direction as usual (0 North, 90 East, etc);
features[i].properties.dirType : 1 - single, if a user selects "To me" or "Opposite" (then "dir" above is "move_dir"+180), 2 - both directions;
features[i].properties.liveUntil - UTC-time when submitted point expires (mobiles expire in 3 hours, fixed cameras in 14 days if no one "liked" them), every thumbUp/thumbDown report changes this time;
features[i].properties.likes/dislikes - number of thumbUp/thumbDown reports;
features[i].properties.createdAt - UTC-time of submission;
features[i].properties.author - null if a user didnt grant STA to send his name or when endpoint request is unauthorized.
features[i].geometry.type - always "Point"
features[i].geometry.coordinates - is the array with longitude and latitude.
Submitted points always appear in STA while current time is less than features[i].properties.liveUntil.
The endpoint currently returns points submitted from phones with "en-GB" or "en-US" languages set.
Endpoint interval parameter - selects points whose liveUntil property is greater or equal than current UTC minus interval
No such option currently.
The reason of that was the fact that every added SPECS requires second, finishing point for correct work. User may forget to add it, leave the track earlier, etc. Generally, submitting avg. section from the app while driving requires much more efforts from a user.
My suggestion: I'll add SPECS icon to the blue report window, submitted point will have type 1, but with the comment "SPECS". Then after filtering out such points on map, you'll decide where is the start, mids and finish. What do you think ?
Posted: Fri Oct 06, 2023 3:29 pm Post subject:
Hi Leo, yes, I understand your reasoning and needing to keep it as simple as possible for the driver.
That would work as I manually check through the submissions before they even get to the 'pending' database for checking.
You can post new topics in this forum You can reply to topics in this forum You can edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
